Motors stopping between commands
Results 1 to 6 of 6
Thread: Motors stopping between commands
    Jul 2017
    Default Motors stopping between commands
    I am having a hard time preventing the motors from stopping completely between commands when running a loop with M97.
    I need to repeat a circle many times. If I copy/paste the circle command, the motors never stop and continuously do 10 circles. When I use a M97 command to loop the circle command, the motors stop between each circles, producing a "toc" sound. I can also feel the "toc" with my hand. Is there any way to prevent this?
    Feb 2006
    india
    Default Re: Motors stopping between commands
    Not sure about your control.
    Are you using Fanuc equivalent of M98 P0101234 for executing O1234 ten times, with O1234 having the circle command?
    Jul 2017
    I am using a Aerotech 3200. I use
    M97 L10 P1234
    N1234 G3 etc...
    The problem is that it decelerates and reaccelerates between iterations in the loop whereas if I put multiple circle commands one after the other (instead of a loop), it's a continuous movement.
    Feb 2006
    india
    I think it is expected, and nothing can be done about it.
    Jul 2017
    I had a feeling it would be the case. I'll just generate the code instead of looping. Thanks!
    CNCFr's Avatar
    Sep 2002
    Timbuktu
    It requires a certain time to transfer the M97-information from the NC-control to the PLC. If you write M97 in a dedicated block I don't see a way how to prevent the axes from stopping.
    There are controls which can do the M-code output while the axes are travelling if M97 and travel commands are written in one block. But the exact behaviour in this case may also depend on machine parameters.
    I don't know the control you are using. But I think it would be worth some experimenting.
