It may be that cutting 6 mm deep draws more power/current (than 3 mm), which creates more noise on the motor control lines. Solving noise problems is an arcane art.
Cheers
Roger
hello,
i have build my own cnc machine. when i cut a square 200mm x 200mm wood, and i cut it with 3mm depth per go. it cuts perfect.
but when i try the same square but then cut is 6mm depth in one go it is 1mm to big. on the x and y axis.
i use universal gcode sender.
does any of you guys have an idea?
sorry for my bad english.
- Need Help!- Diffrent cuts depth
- Need Help!- Depth of Cuts
- Newbie- Feeds and depth of roughing cuts:
- Typical Depth of Cuts for steel
- MCX depth cuts question
Cheers
Roger
[QUOTE=RCaffin;2047762]It may be that cutting 6 mm deep draws more power/current (than 3 mm), which creates more noise on the motor control lines. Solving noise problems is an arcane art.
Cheers
Hello, thanks for the reply.
Solving noise problems is there a way to do this?
Is it changing some grbl like settings?
And yes, with ones?
Thank you
Yes, of course, but even experts can be tearing their hair out.
You may need to find some teenage electronics hacker for this. He will need to be fairly experienced. It is not something which can be explained over the web.
Sorry - I did say it can be extremely difficult!
Cheers
Roger
Check your rigidity and backlash. At 6 mm the forces on the bit are at least double those at 3mm and it could be distorting the entire machine.
Dave
In the words of the Toolman--If you didn't make it yourself, it's not really yours!
Remember- done beats perfect every time!!
[QUOTE=beone;2047792]Check your rigidity and backlash. At 6 mm the forces on the bit are at least double those at 3mm and it could be distorting the entire machine.
Hello Dave,
The machine is pretty strong. But if it is not as strong as I think would it not make the square smaller and out of shape? And not bigger?
Greetings
Normally, but strange things can happen.
Research time.
Cut some squares at varying depths (1,2,3,4,5,6 mm) and see what the errors look like.
Cut some squares 50, 100, 150, 200 mm square at 3 mm and 6 mm depth and see what the errors look like.
When you cut a square 200 x 200 mm at 6 mm depth, does the spindle return to exactly 0,0 at the end, or is it off?
Each test will tell you something useful.
Cheers
Roger
[QUOTE=RCaffin;2048802]would it not make the square smaller and out of shape?
Research time.
Cheers
I Wil try this. Next week. I have no time this week.
When I did it I Wil post again.
