This is the simulation screenshot
Attachment 360188
So it`s like a letter C
It`s definitely not you boss, im pointing my comment to the thread starter or the original poster, you are a 5 star General around here and im like aspiring to be private E-1 not even close to E-1
can anybody make a simulation video of what the OP meant on an ARC? my own understanding of an arc is it`s like a C or am I wrong?
Attachment 360188
Every single line of g-code, whether a straight line or an arc, requires you to know the cutter diameter.G02 X5.25 Y-1.5 I0 J1.75.......according to the notes I have......you would have to know precisely the diam of the cutter and also that it is not running out of round and so giving you a different cutter radius.
Unless you're using G41/G42 comp, in which case it doesn't matter, regardless of whether you're using IJ arcs or R arcs.
You're over complicating things. Or not understanding.
UCCNC 2017 Screenset
Well I thought using the R notation was simplifying things........using the R notation to create an arc at the corner of the plate does not require you to calculate the cutter diam (or radius) in the coding......that is up to Mach 3 to refer to the tool register when it creates the arc......using the I and J notation requires you to manually calculate the code with the cutter diam added to the X and Y values.
To refresh the memory.....
G02 X5 Y-1.5 R1.5 creates the radius and there is no mention of a cutter diam in that line of code......that is ultra simple as the tool diam is already in the Mach3 tool register.
It gets even more confusing if the part you are making is in Imperial dimensions (customers's drawing etc) and your cutter specs in the tool register are all Metric.
From post #15....... I get confused with the I value at 0....can't understand why this is so.
Ian.
X and Y are the start and end points They are what they are. You're not adding diameter to anything. Both R arcs and IJ arcs have the same X and Y coordinates.Well I thought using the R notation was simplifying things........using the R notation to create an arc at the corner of the plate does not require you to calculate the cutter diam (or radius) in the coding......that is up to Mach 3 to refer to the tool register when it creates the arc......using the I and J notation requires you to manually calculate the code with the cutter diam added to the X and Y values.
Here is the shape I use for testing code. It has both G2 and G3 moves, with both full circles and arcs starting and ending at odd points. Put the shape in different quadrants and crossing quadrants. Allows testing of all possibilities. Also the G code contains both I, J and R, Start, End
Use ''Toolpath to Geometry'' to create a dxf from the G code.
( MADE USING CAMBAM - HTTP://WWW.CAMBAM.CO.UK )
( ARC TEST 12/5/2016 18:29:51 )
( T0 : 0.0 )
G20 G90 G64 G40
( ENGRAVE1 )
G17
M3 S1000
G0 Z0.125 W0.0
G0 X-3.9824 Y-1.9835 Z0.125 W0.0
G0 X-3.9824 Y-1.9835 Z0.0625 W0.0
G1 F10.0 X-3.9824 Y-1.9835 Z-0.015 W0.0
M7
G1 F30.0 X-7.9824 Y-1.9835 Z-0.015 W0.0
G2 F30.0 X-11.9824 Y-1.9835 Z-0.015 I-2.0 J0.0 R2.0 S0.0 E-180.0
G1 F30.0 X-13.9824 Y-1.9835 Z-0.015 W0.0
G3 F30.0 X-15.9824 Y-3.9835 Z-0.015 I0.0 J-2.0 R2.0 S90.0 E90.0
G1 F30.0 X-15.9824 Y-7.9835 Z-0.015 W0.0
G3 F30.0 X-13.9824 Y-9.9835 Z-0.015 I2.0 J0.0 R2.0 S180.0 E90.0
G1 F30.0 X-12.4319 Y-9.9835 Z-0.015 W0.0
G1 F30.0 X-12.4319 Y-9.4835 Z-0.015 W0.0
G2 F30.0 X-7.6911 Y-8.9835 Z-0.015 I2.4495 J-0.5 R2.5 S168.463 E-144.8849
G1 F30.0 X-7.6911 Y-9.9835 Z-0.015 W0.0
G1 F30.0 X-3.9824 Y-9.9835 Z-0.015 W0.0
G3 F30.0 X-1.9824 Y-7.9835 Z-0.015 I0.0 J2.0 R2.0 S-90.0 E90.0
G1 F30.0 X-5.9824 Y-7.9835 Z-0.015 W0.0
G2 F30.0 X-6.4824 Y-4.047 Z-0.015 I0.0 J2.0 R2.0 S-90.0 E-165.5225
G1 F30.0 X-1.9824 Y-4.047 Z-0.015 W0.0
G1 F30.0 X-1.9824 Y-3.9835 Z-0.015 W0.0
G3 F30.0 X-3.9824 Y-1.9835 Z-0.015 I-2.0 J0.0 R2.0 S0.0 E90.0
M9
G0 X-13.0539 Y-5.6121 Z0.125 W0.0
G0 X-13.0539 Y-5.6121 Z0.0625 W0.0
G1 F10.0 X-13.0539 Y-5.6121 Z-0.015 W0.0
M7
G3 F30.0 X-14.4824 Y-5.1175 Z-0.015 I-0.9285 J-0.3714 R1.0 S21.8014 E98.1986
G3 F30.0 X-14.4824 Y-6.8495 Z-0.015 I0.5 J-0.866 R1.0 S120.0 E120.0
G3 F30.0 X-12.9824 Y-5.9835 Z-0.015 I0.5 J0.866 R1.0 S-120.0 E120.0
G3 F30.0 X-13.0539 Y-5.6121 Z-0.015 I-1.0 J0.0 R1.0 S0.0 E21.8014
M9
M5
M30
Highly confusing........I need to understand how the coding sequence works......I'll have to gen up to get more knowledgeable or this thread will wander around in circles.....my fault entirely......thanks for your time, much appreciated.
Ian.
Here`s a freestyle version of your shape sir drawn and routed under 2 minutes, I cut the circle first to be more realistic then the outline, I added an auto zero to reload material to the jig and start all over again
Code:( T0 : 0.0 ) G21 G90 G91.1 G64 G40 G0 Z3.0 ( T0 : 0.0 ) T0 M6 ( 1 ) G17 M3 S1000 G0 X34.755 Y-105.2152 G0 Z1.0 G1 F30.0 Z0.0 G1 X34.1887 Y-103.9064 G1 X33.7056 Y-102.5647 G1 X33.3078 Y-101.1953 G1 X32.9967 Y-99.8036 G1 X32.7736 Y-98.3951 G1 X32.6394 Y-96.9753 G1 X32.5946 Y-95.55 G1 X32.6394 Y-94.1247 G1 X32.7736 Y-92.7049 G1 X32.9967 Y-91.2964 G1 X33.3078 Y-89.9047 G1 X33.7056 Y-88.5353 G1 X34.1887 Y-87.1936 G1 X34.755 Y-85.8848 G1 X35.4025 Y-84.6142 G1 X36.1284 Y-83.3867 G1 X36.9299 Y-82.2073 G1 X37.804 Y-81.0805 G1 X38.747 Y-80.0108 G1 X39.7554 Y-79.0024 G1 X40.8251 Y-78.0593 G1 X41.9519 Y-77.1853 G1 X43.1314 Y-76.3838 G1 X44.3588 Y-75.6578 G1 X45.6294 Y-75.0104 G1 X46.9382 Y-74.4441 G1 X48.2799 Y-73.961 G1 X49.6494 Y-73.5632 G1 X51.0411 Y-73.2521 G1 X52.4496 Y-73.029 G1 X53.8693 Y-72.8948 G1 X55.2946 Y-72.85 G1 X56.72 Y-72.8948 G1 X58.1397 Y-73.029 G1 X59.5482 Y-73.2521 G1 X60.9399 Y-73.5632 G1 X62.3093 Y-73.961 G1 X63.651 Y-74.4441 G1 X64.9598 Y-75.0104 G1 X66.2304 Y-75.6578 G1 X67.4579 Y-76.3838 G1 X68.6373 Y-77.1853 G1 X69.7641 Y-78.0593 G1 X70.8338 Y-79.0024 G1 X71.8422 Y-80.0108 G1 X72.7853 Y-81.0805 G1 X73.6593 Y-82.2073 G1 X74.4609 Y-83.3867 G1 X75.1868 Y-84.6142 G1 X75.8342 Y-85.8848 G1 X76.4005 Y-87.1936 G1 X76.8836 Y-88.5353 G1 X77.2815 Y-89.9047 G1 X77.5925 Y-91.2964 G1 X77.8156 Y-92.7049 G1 X77.9498 Y-94.1247 G1 X77.9946 Y-95.55 G1 X77.9498 Y-96.9753 G1 X77.8156 Y-98.3951 G1 X77.5925 Y-99.8036 G1 X77.2815 Y-101.1953 G1 X76.8836 Y-102.5647 G1 X76.4005 Y-103.9064 G1 X75.8342 Y-105.2152 G1 X75.1868 Y-106.4858 G1 X74.4609 Y-107.7133 G1 X73.6593 Y-108.8927 G1 X72.7853 Y-110.0195 G1 X71.8422 Y-111.0892 G1 X70.8338 Y-112.0976 G1 X69.7641 Y-113.0407 G1 X68.6373 Y-113.9147 G1 X67.4579 Y-114.7162 G1 X66.2304 Y-115.4422 G1 X64.9598 Y-116.0896 G1 X63.651 Y-116.6559 G1 X62.3093 Y-117.139 G1 X60.9399 Y-117.5368 G1 X59.5482 Y-117.8479 G1 X58.1397 Y-118.071 G1 X56.72 Y-118.2052 G1 X55.2946 Y-118.25 G1 X53.8693 Y-118.2052 G1 X52.4496 Y-118.071 G1 X51.0411 Y-117.8479 G1 X49.6494 Y-117.5368 G1 X48.2799 Y-117.139 G1 X46.9382 Y-116.6559 G1 X45.6294 Y-116.0896 G1 X44.3588 Y-115.4422 G1 X43.1314 Y-114.7162 G1 X41.9519 Y-113.9147 G1 X40.8251 Y-113.0407 G1 X39.7554 Y-112.0976 G1 X38.747 Y-111.0892 G1 X37.804 Y-110.0195 G1 X36.9299 Y-108.8927 G1 X36.1284 Y-107.7133 G1 X35.4025 Y-106.4858 G1 X34.755 Y-105.2152 ( 2 ) S1000 G0 Z3.0 G0 X67.0153 Y0.0 G0 Z1.0 G1 Z0.0 G1 X67.0573 Y-1.9778 G1 X67.1832 Y-3.952 G1 X67.3927 Y-5.919 G1 X67.6856 Y-7.8754 G1 X68.0612 Y-9.8177 G1 X68.5189 Y-11.7422 G1 X69.0579 Y-13.6455 G1 X69.6772 Y-15.5243 G1 X70.3757 Y-17.3751 G1 X71.152 Y-19.1946 G1 X72.0049 Y-20.9795 G1 X72.9328 Y-22.7266 G1 X73.934 Y-24.4327 G1 X75.0067 Y-26.0948 G1 X76.149 Y-27.7099 G1 X77.3588 Y-29.2751 G1 X78.634 Y-30.7874 G1 X79.9721 Y-32.2444 G1 X81.3709 Y-33.6432 G1 X82.8278 Y-34.9813 G1 X84.3402 Y-36.2565 G1 X85.9054 Y-37.4663 G1 X87.5205 Y-38.6085 G1 X89.1826 Y-39.6813 G1 X90.8887 Y-40.6825 G1 X92.6358 Y-41.6103 G1 X94.4207 Y-42.4632 G1 X96.2402 Y-43.2396 G1 X98.091 Y-43.9381 G1 X99.9697 Y-44.5574 G1 X101.8731 Y-45.0964 G1 X103.7976 Y-45.5541 G1 X105.7398 Y-45.9297 G1 X107.6963 Y-46.2226 G1 X109.6633 Y-46.4321 G1 X111.6375 Y-46.558 G1 X113.6153 Y-46.6 G1 X115.593 Y-46.558 G1 X117.5672 Y-46.4321 G1 X119.5343 Y-46.2226 G1 X121.4907 Y-45.9297 G1 X123.4329 Y-45.5541 G1 X125.3575 Y-45.0964 G1 X127.2608 Y-44.5574 G1 X129.1396 Y-43.9381 G1 X130.9904 Y-43.2396 G1 X132.8099 Y-42.4632 G1 X134.5948 Y-41.6103 G1 X136.3419 Y-40.6825 G1 X138.048 Y-39.6813 G1 X139.7101 Y-38.6085 G1 X141.3252 Y-37.4663 G1 X142.8903 Y-36.2565 G1 X144.4027 Y-34.9813 G1 X145.8596 Y-33.6432 G1 X147.2584 Y-32.2444 G1 X148.5966 Y-30.7874 G1 X149.8718 Y-29.2751 G1 X151.0816 Y-27.7099 G1 X152.2238 Y-26.0948 G1 X153.2965 Y-24.4327 G1 X154.2977 Y-22.7266 G1 X155.2256 Y-20.9795 G1 X156.0785 Y-19.1946 G1 X156.8549 Y-17.3751 G1 X157.5534 Y-15.5243 G1 X158.1727 Y-13.6455 G1 X158.7116 Y-11.7422 G1 X159.1694 Y-9.8177 G1 X159.545 Y-7.8754 G1 X159.8378 Y-5.919 G1 X160.0474 Y-3.952 G1 X160.1733 Y-1.9778 G1 X160.2153 Y0.0 G0 Z3.0 G0 X159.8167 G0 Z1.0 G1 Z0.0 G1 X250.2 G1 X250.6916 Y-0.0039 G1 X251.1832 Y-0.0154 G1 X251.6744 Y-0.0347 G1 X252.1653 Y-0.0618 G1 X252.6558 Y-0.0965 G1 X253.1456 Y-0.1389 G1 X253.6347 Y-0.189 G1 X254.1229 Y-0.2468 G1 X254.6102 Y-0.3123 G1 X255.0964 Y-0.3854 G1 X255.5814 Y-0.4661 G1 X256.065 Y-0.5544 G1 X256.5472 Y-0.6503 G1 X257.0279 Y-0.7538 G1 X257.5068 Y-0.8648 G1 X257.984 Y-0.9833 G1 X258.4592 Y-1.1094 G1 X258.9324 Y-1.2428 G1 X259.4035 Y-1.3837 G1 X259.8722 Y-1.5319 G1 X260.3386 Y-1.6875 G1 X260.8025 Y-1.8504 G1 X261.2638 Y-2.0206 G1 X261.7223 Y-2.198 G1 X262.178 Y-2.3826 G1 X262.6307 Y-2.5743 G1 X263.0804 Y-2.7731 G1 X263.5269 Y-2.9789 G1 X263.9701 Y-3.1917 G1 X264.4099 Y-3.4115 G1 X264.8462 Y-3.6381 G1 X265.2789 Y-3.8716 G1 X265.7079 Y-4.1118 G1 X266.133 Y-4.3588 G1 X266.5542 Y-4.6124 G1 X266.9714 Y-4.8725 G1 X267.3844 Y-5.1392 G1 X267.7932 Y-5.4124 G1 X268.1977 Y-5.6919 G1 X268.5977 Y-5.9778 G1 X268.9932 Y-6.2699 G1 X269.384 Y-6.5681 G1 X269.7701 Y-6.8725 G1 X270.1514 Y-7.1829 G1 X270.5277 Y-7.4993 G1 X270.8991 Y-7.8215 G1 X271.2653 Y-8.1495 G1 X271.6263 Y-8.4833 G1 X271.9821 Y-8.8226 G1 X272.3324 Y-9.1676 G1 X272.6774 Y-9.5179 G1 X273.0167 Y-9.8737 G1 X273.3505 Y-10.2347 G1 X273.6785 Y-10.6009 G1 X274.0007 Y-10.9723 G1 X274.3171 Y-11.3486 G1 X274.6275 Y-11.7299 G1 X274.9319 Y-12.116 G1 X275.2301 Y-12.5068 G1 X275.5222 Y-12.9023 G1 X275.8081 Y-13.3023 G1 X276.0876 Y-13.7068 G1 X276.3608 Y-14.1156 G1 X276.6275 Y-14.5286 G1 X276.8876 Y-14.9458 G1 X277.1412 Y-15.367 G1 X277.3882 Y-15.7921 G1 X277.6284 Y-16.2211 G1 X277.8619 Y-16.6538 G1 X278.0885 Y-17.0901 G1 X278.3083 Y-17.5299 G1 X278.5211 Y-17.9731 G1 X278.7269 Y-18.4196 G1 X278.9257 Y-18.8693 G1 X279.1174 Y-19.322 G1 X279.302 Y-19.7777 G1 X279.4794 Y-20.2362 G1 X279.6496 Y-20.6975 G1 X279.8125 Y-21.1614 G1 X279.9681 Y-21.6278 G1 X280.1163 Y-22.0965 G1 X280.2572 Y-22.5676 G1 X280.3906 Y-23.0408 G1 X280.5167 Y-23.516 G1 X280.6352 Y-23.9932 G1 X280.7462 Y-24.4721 G1 X280.8497 Y-24.9528 G1 X280.9456 Y-25.435 G1 X281.0339 Y-25.9186 G1 X281.1146 Y-26.4036 G1 X281.1877 Y-26.8898 G1 X281.2532 Y-27.3771 G1 X281.311 Y-27.8653 G1 X281.3611 Y-28.3544 G1 X281.4035 Y-28.8442 G1 X281.4382 Y-29.3347 G1 X281.4653 Y-29.8256 G1 X281.4846 Y-30.3168 G1 X281.4961 Y-30.8084 G1 X281.5 Y-31.3 G1 Y-56.45 G1 X186.4945 G1 X184.8787 Y-56.4834 G1 X183.2656 Y-56.5835 G1 X181.6581 Y-56.7503 G1 X180.0588 Y-56.9833 G1 X178.4706 Y-57.2822 G1 X176.896 Y-57.6464 G1 X175.3378 Y-58.0755 G1 X173.7987 Y-58.5685 G1 X172.2813 Y-59.1248 G1 X170.7882 Y-59.7433 G1 X169.3219 Y-60.4229 G1 X167.8849 Y-61.1626 G1 X166.4798 Y-61.961 G1 X165.1088 Y-62.8168 G1 X163.7744 Y-63.7285 G1 X162.4788 Y-64.6946 G1 X161.2242 Y-65.7134 G1 X160.0128 Y-66.7832 G1 X158.8466 Y-67.9021 G1 X157.7277 Y-69.0683 G1 X156.6579 Y-70.2797 G1 X155.6391 Y-71.5343 G1 X154.673 Y-72.8299 G1 X153.7613 Y-74.1643 G1 X152.9055 Y-75.5353 G1 X152.1071 Y-76.9405 G1 X151.3674 Y-78.3774 G1 X150.6877 Y-79.8437 G1 X150.0693 Y-81.3368 G1 X149.513 Y-82.8543 G1 X149.02 Y-84.3934 G1 X148.5909 Y-85.9515 G1 X148.2266 Y-87.5261 G1 X147.9278 Y-89.1144 G1 X147.6947 Y-90.7136 G1 X147.528 Y-92.3211 G1 X147.4279 Y-93.9342 G1 X147.3945 Y-95.55 G1 X147.4279 Y-97.1658 G1 X147.528 Y-98.7789 G1 X147.6947 Y-100.3864 G1 X147.9278 Y-101.9856 G1 X148.2266 Y-103.5739 G1 X148.5909 Y-105.1485 G1 X149.02 Y-106.7066 G1 X149.513 Y-108.2457 G1 X150.0693 Y-109.7632 G1 X150.6877 Y-111.2563 G1 X151.3674 Y-112.7226 G1 X152.1071 Y-114.1595 G1 X152.9055 Y-115.5647 G1 X153.7613 Y-116.9357 G1 X154.673 Y-118.2701 G1 X155.6391 Y-119.5657 G1 X156.6579 Y-120.8203 G1 X157.7277 Y-122.0317 G1 X158.8466 Y-123.1979 G1 X160.0128 Y-124.3168 G1 X161.2242 Y-125.3866 G1 X162.4788 Y-126.4054 G1 X163.7744 Y-127.3715 G1 X165.1088 Y-128.2832 G1 X166.4798 Y-129.139 G1 X167.8849 Y-129.9374 G1 X169.3219 Y-130.6771 G1 X170.7882 Y-131.3567 G1 X172.2813 Y-131.9752 G1 X173.7987 Y-132.5315 G1 X175.3378 Y-133.0245 G1 X176.896 Y-133.4536 G1 X178.4706 Y-133.8178 G1 X180.0588 Y-134.1167 G1 X181.6581 Y-134.3497 G1 X183.2656 Y-134.5165 G1 X184.8787 Y-134.6166 G1 X186.4945 Y-134.65 G1 X281.5 G1 Y-159.8 G1 X281.4961 Y-160.2916 G1 X281.4846 Y-160.7832 G1 X281.4653 Y-161.2744 G1 X281.4382 Y-161.7653 G1 X281.4035 Y-162.2558 G1 X281.3611 Y-162.7456 G1 X281.311 Y-163.2347 G1 X281.2532 Y-163.7229 G1 X281.1877 Y-164.2102 G1 X281.1146 Y-164.6964 G1 X281.0339 Y-165.1814 G1 X280.9456 Y-165.665 G1 X280.8497 Y-166.1472 G1 X280.7462 Y-166.6279 G1 X280.6352 Y-167.1068 G1 X280.5167 Y-167.584 G1 X280.3906 Y-168.0592 G1 X280.2572 Y-168.5324 G1 X280.1163 Y-169.0035 G1 X279.9681 Y-169.4722 G1 X279.8125 Y-169.9386 G1 X279.6496 Y-170.4025 G1 X279.4794 Y-170.8638 G1 X279.302 Y-171.3223 G1 X279.1174 Y-171.778 G1 X278.9257 Y-172.2307 G1 X278.7269 Y-172.6804 G1 X278.5211 Y-173.1269 G1 X278.3083 Y-173.5701 G1 X278.0885 Y-174.0099 G1 X277.8619 Y-174.4462 G1 X277.6284 Y-174.8789 G1 X277.3882 Y-175.3079 G1 X277.1412 Y-175.733 G1 X276.8876 Y-176.1542 G1 X276.6275 Y-176.5714 G1 X276.3608 Y-176.9844 G1 X276.0876 Y-177.3932 G1 X275.8081 Y-177.7977 G1 X275.5222 Y-178.1977 G1 X275.2301 Y-178.5932 G1 X274.9319 Y-178.984 G1 X274.6275 Y-179.3701 G1 X274.3171 Y-179.7514 G1 X274.0007 Y-180.1277 G1 X273.6785 Y-180.4991 G1 X273.3505 Y-180.8653 G1 X273.0167 Y-181.2263 G1 X272.6774 Y-181.5821 G1 X272.3324 Y-181.9324 G1 X271.9821 Y-182.2774 G1 X271.6263 Y-182.6167 G1 X271.2653 Y-182.9505 G1 X270.8991 Y-183.2785 G1 X270.5277 Y-183.6007 G1 X270.1514 Y-183.9171 G1 X269.7701 Y-184.2275 G1 X269.384 Y-184.5319 G1 X268.9932 Y-184.8301 G1 X268.5977 Y-185.1222 G1 X268.1977 Y-185.4081 G1 X267.7932 Y-185.6876 G1 X267.3844 Y-185.9608 G1 X266.9714 Y-186.2275 G1 X266.5542 Y-186.4876 G1 X266.133 Y-186.7412 G1 X265.7079 Y-186.9882 G1 X265.2789 Y-187.2284 G1 X264.8462 Y-187.4619 G1 X264.4099 Y-187.6885 G1 X263.9701 Y-187.9083 G1 X263.5269 Y-188.1211 G1 X263.0804 Y-188.3269 G1 X262.6307 Y-188.5257 G1 X262.178 Y-188.7174 G1 X261.7223 Y-188.902 G1 X261.2638 Y-189.0794 G1 X260.8025 Y-189.2496 G1 X260.3386 Y-189.4125 G1 X259.8722 Y-189.5681 G1 X259.4035 Y-189.7163 G1 X258.9324 Y-189.8572 G1 X258.4592 Y-189.9906 G1 X257.984 Y-190.1167 G1 X257.5068 Y-190.2352 G1 X257.0279 Y-190.3462 G1 X256.5472 Y-190.4497 G1 X256.065 Y-190.5456 G1 X255.5814 Y-190.6339 G1 X255.0964 Y-190.7146 G1 X254.6102 Y-190.7877 G1 X254.1229 Y-190.8532 G1 X253.6347 Y-190.911 G1 X253.1456 Y-190.9611 G1 X252.6558 Y-191.0035 G1 X252.1653 Y-191.0382 G1 X251.6744 Y-191.0653 G1 X251.1832 Y-191.0846 G1 X250.6916 Y-191.0961 G1 X250.2 Y-191.1 G1 X158.7688 G1 Y-171.5603 G1 X158.1328 Y-170.1517 G1 X157.4528 Y-168.7637 G1 X156.7296 Y-167.3977 G1 X155.9638 Y-166.0552 G1 X155.1562 Y-164.7373 G1 X154.3076 Y-163.4455 G1 X153.4189 Y-162.181 G1 X152.4909 Y-160.945 G1 X151.5245 Y-159.7387 G1 X150.5207 Y-158.5635 G1 X149.4805 Y-157.4203 G1 X148.4049 Y-156.3103 G1 X147.295 Y-155.2347 G1 X146.1518 Y-154.1945 G1 X144.9765 Y-153.1907 G1 X143.7703 Y-152.2244 G1 X142.5343 Y-151.2964 G1 X141.2698 Y-150.4076 G1 X139.978 Y-149.5591 G1 X138.6601 Y-148.7515 G1 X137.3176 Y-147.9857 G1 X135.9516 Y-147.2625 G1 X134.5636 Y-146.5825 G1 X133.155 Y-145.9465 G1 X131.727 Y-145.355 G1 X130.2812 Y-144.8087 G1 X128.8189 Y-144.308 G1 X127.3416 Y-143.8536 G1 X125.8508 Y-143.4457 G1 X124.3479 Y-143.0849 G1 X122.8344 Y-142.7715 G1 X121.3119 Y-142.5057 G1 X119.7817 Y-142.288 G1 X118.2454 Y-142.1184 G1 X116.7046 Y-141.9971 G1 X115.1607 Y-141.9243 G1 X113.6153 Y-141.9 G1 X112.0699 Y-141.9243 G1 X110.526 Y-141.9971 G1 X108.9852 Y-142.1184 G1 X107.4489 Y-142.288 G1 X105.9187 Y-142.5057 G1 X104.3961 Y-142.7715 G1 X102.8826 Y-143.0849 G1 X101.3797 Y-143.4457 G1 X99.8889 Y-143.8536 G1 X98.4116 Y-144.308 G1 X96.9494 Y-144.8087 G1 X95.5036 Y-145.355 G1 X94.0756 Y-145.9465 G1 X92.6669 Y-146.5825 G1 X91.279 Y-147.2625 G1 X89.913 Y-147.9857 G1 X88.5704 Y-148.7515 G1 X87.2526 Y-149.5591 G1 X85.9608 Y-150.4076 G1 X84.6962 Y-151.2964 G1 X83.4603 Y-152.2244 G1 X82.254 Y-153.1907 G1 X81.0787 Y-154.1945 G1 X79.9356 Y-155.2347 G1 X78.8256 Y-156.3103 G1 X77.75 Y-157.4203 G1 X76.7098 Y-158.5635 G1 X75.706 Y-159.7387 G1 X74.7397 Y-160.945 G1 X73.8116 Y-162.181 G1 X72.9229 Y-163.4455 G1 X72.0744 Y-164.7373 G1 X71.2668 Y-166.0552 G1 X70.501 Y-167.3977 G1 X69.7778 Y-168.7637 G1 X69.0978 Y-170.1517 G1 X68.4618 Y-171.5603 G1 X67.8703 Y-172.9883 G1 X67.324 Y-174.4341 G1 X66.8233 Y-175.8964 G1 X66.3688 Y-177.3736 G1 X65.961 Y-178.8645 G1 X65.6002 Y-180.3674 G1 X65.2868 Y-181.8808 G1 X65.021 Y-183.4034 G1 X64.8032 Y-184.9336 G1 X64.6336 Y-186.4699 G1 X64.5124 Y-188.0107 G1 X64.4396 Y-189.5546 G1 X64.4153 Y-191.1 G1 X32.3 G1 X31.8084 Y-191.0961 G1 X31.3168 Y-191.0846 G1 X30.8256 Y-191.0653 G1 X30.3347 Y-191.0382 G1 X29.8442 Y-191.0035 G1 X29.3544 Y-190.9611 G1 X28.8653 Y-190.911 G1 X28.3771 Y-190.8532 G1 X27.8898 Y-190.7877 G1 X27.4036 Y-190.7146 G1 X26.9186 Y-190.6339 G1 X26.435 Y-190.5456 G1 X25.9528 Y-190.4497 G1 X25.4721 Y-190.3462 G1 X24.9932 Y-190.2352 G1 X24.516 Y-190.1167 G1 X24.0408 Y-189.9906 G1 X23.5676 Y-189.8572 G1 X23.0965 Y-189.7163 G1 X22.6278 Y-189.5681 G1 X22.1614 Y-189.4125 G1 X21.6975 Y-189.2496 G1 X21.2362 Y-189.0794 G1 X20.7777 Y-188.902 G1 X20.322 Y-188.7174 G1 X19.8693 Y-188.5257 G1 X19.4196 Y-188.3269 G1 X18.9731 Y-188.1211 G1 X18.5299 Y-187.9083 G1 X18.0901 Y-187.6885 G1 X17.6538 Y-187.4619 G1 X17.2211 Y-187.2284 G1 X16.7921 Y-186.9882 G1 X16.367 Y-186.7412 G1 X15.9458 Y-186.4876 G1 X15.5286 Y-186.2275 G1 X15.1156 Y-185.9608 G1 X14.7068 Y-185.6876 G1 X14.3023 Y-185.4081 G1 X13.9023 Y-185.1222 G1 X13.5068 Y-184.8301 G1 X13.116 Y-184.5319 G1 X12.7299 Y-184.2275 G1 X12.3486 Y-183.9171 G1 X11.9723 Y-183.6007 G1 X11.6009 Y-183.2785 G1 X11.2347 Y-182.9505 G1 X10.8737 Y-182.6167 G1 X10.5179 Y-182.2774 G1 X10.1676 Y-181.9324 G1 X9.8226 Y-181.5821 G1 X9.4833 Y-181.2263 G1 X9.1495 Y-180.8653 G1 X8.8215 Y-180.4991 G1 X8.4993 Y-180.1277 G1 X8.1829 Y-179.7514 G1 X7.8725 Y-179.3701 G1 X7.5681 Y-178.984 G1 X7.2699 Y-178.5932 G1 X6.9778 Y-178.1977 G1 X6.6919 Y-177.7977 G1 X6.4124 Y-177.3932 G1 X6.1392 Y-176.9844 G1 X5.8725 Y-176.5714 G1 X5.6124 Y-176.1542 G1 X5.3588 Y-175.733 G1 X5.1118 Y-175.3079 G1 X4.8716 Y-174.8789 G1 X4.6381 Y-174.4462 G1 X4.4115 Y-174.0099 G1 X4.1917 Y-173.5701 G1 X3.9789 Y-173.1269 G1 X3.7731 Y-172.6804 G1 X3.5743 Y-172.2307 G1 X3.3826 Y-171.778 G1 X3.198 Y-171.3223 G1 X3.0206 Y-170.8638 G1 X2.8504 Y-170.4025 G1 X2.6875 Y-169.9386 G1 X2.5319 Y-169.4722 G1 X2.3837 Y-169.0035 G1 X2.2428 Y-168.5324 G1 X2.1094 Y-168.0592 G1 X1.9833 Y-167.584 G1 X1.8648 Y-167.1068 G1 X1.7538 Y-166.6279 G1 X1.6503 Y-166.1472 G1 X1.5544 Y-165.665 G1 X1.4661 Y-165.1814 G1 X1.3854 Y-164.6964 G1 X1.3123 Y-164.2102 G1 X1.2468 Y-163.7229 G1 X1.189 Y-163.2347 G1 X1.1389 Y-162.7456 G1 X1.0965 Y-162.2558 G1 X1.0618 Y-161.7653 G1 X1.0347 Y-161.2744 G1 X1.0154 Y-160.7832 G1 X1.0039 Y-160.2916 G1 X1.0 Y-159.8 G1 Y-31.3 G1 X1.0039 Y-30.8084 G1 X1.0154 Y-30.3168 G1 X1.0347 Y-29.8256 G1 X1.0618 Y-29.3347 G1 X1.0965 Y-28.8442 G1 X1.1389 Y-28.3544 G1 X1.189 Y-27.8653 G1 X1.2468 Y-27.3771 G1 X1.3123 Y-26.8898 G1 X1.3854 Y-26.4036 G1 X1.4661 Y-25.9186 G1 X1.5544 Y-25.435 G1 X1.6503 Y-24.9528 G1 X1.7538 Y-24.4721 G1 X1.8648 Y-23.9932 G1 X1.9833 Y-23.516 G1 X2.1094 Y-23.0408 G1 X2.2428 Y-22.5676 G1 X2.3837 Y-22.0965 G1 X2.5319 Y-21.6278 G1 X2.6875 Y-21.1614 G1 X2.8504 Y-20.6975 G1 X3.0206 Y-20.2362 G1 X3.198 Y-19.7777 G1 X3.3826 Y-19.322 G1 X3.5743 Y-18.8693 G1 X3.7731 Y-18.4196 G1 X3.9789 Y-17.9731 G1 X4.1917 Y-17.5299 G1 X4.4115 Y-17.0901 G1 X4.6381 Y-16.6538 G1 X4.8716 Y-16.2211 G1 X5.1118 Y-15.7921 G1 X5.3588 Y-15.367 G1 X5.6124 Y-14.9458 G1 X5.8725 Y-14.5286 G1 X6.1392 Y-14.1156 G1 X6.4124 Y-13.7068 G1 X6.6919 Y-13.3023 G1 X6.9778 Y-12.9023 G1 X7.2699 Y-12.5068 G1 X7.5681 Y-12.116 G1 X7.8725 Y-11.7299 G1 X8.1829 Y-11.3486 G1 X8.4993 Y-10.9723 G1 X8.8215 Y-10.6009 G1 X9.1495 Y-10.2347 G1 X9.4833 Y-9.8737 G1 X9.8226 Y-9.5179 G1 X10.1676 Y-9.1676 G1 X10.5179 Y-8.8226 G1 X10.8737 Y-8.4833 G1 X11.2347 Y-8.1495 G1 X11.6009 Y-7.8215 G1 X11.9723 Y-7.4993 G1 X12.3486 Y-7.1829 G1 X12.7299 Y-6.8725 G1 X13.116 Y-6.5681 G1 X13.5068 Y-6.2699 G1 X13.9023 Y-5.9778 G1 X14.3023 Y-5.6919 G1 X14.7068 Y-5.4124 G1 X15.1156 Y-5.1392 G1 X15.5286 Y-4.8725 G1 X15.9458 Y-4.6124 G1 X16.367 Y-4.3588 G1 X16.7921 Y-4.1118 G1 X17.2211 Y-3.8716 G1 X17.6538 Y-3.6381 G1 X18.0901 Y-3.4115 G1 X18.5299 Y-3.1917 G1 X18.9731 Y-2.9789 G1 X19.4196 Y-2.7731 G1 X19.8693 Y-2.5743 G1 X20.322 Y-2.3826 G1 X20.7777 Y-2.198 G1 X21.2362 Y-2.0206 G1 X21.6975 Y-1.8504 G1 X22.1614 Y-1.6875 G1 X22.6278 Y-1.5319 G1 X23.0965 Y-1.3837 G1 X23.5676 Y-1.2428 G1 X24.0408 Y-1.1094 G1 X24.516 Y-0.9833 G1 X24.9932 Y-0.8648 G1 X25.4721 Y-0.7538 G1 X25.9528 Y-0.6503 G1 X26.435 Y-0.5544 G1 X26.9186 Y-0.4661 G1 X27.4036 Y-0.3854 G1 X27.8898 Y-0.3123 G1 X28.3771 Y-0.2468 G1 X28.8653 Y-0.189 G1 X29.3544 Y-0.1389 G1 X29.8442 Y-0.0965 G1 X30.3347 Y-0.0618 G1 X30.8256 Y-0.0347 G1 X31.3168 Y-0.0154 G1 X31.8084 Y-0.0039 G1 X32.3 Y0.0 G1 X67.4139 G0 Z3.0 G0 X0 Y0 G0 Z0 M5 M30
LOL.......OK, I just worked out how the radius is coded.......it came in a flash and is logical once you realise that the radius dimensions are INCREMENTAL values while the actual other moves along the straight lines are all ABSOLUTE.........and you don't need to know the cutter dimensions for the coding as the specs for the cutter called up will be in the tool register that Mach 3 automatically refers to and applies to the code.
So.........starting from the left side of a hypothetical 100mm square plate as 0.0 and with a 20mm radius on the right top corner.....the shortened coding movement from 0.0 start would be......
G01 X80
G02 X0 Y-20 I0 J-20.....etc etc as you go round the bend and on down the - Y axis.
If this is also wrong I'll have to fall on my sword and take up knitting to wile away the hours....LOL.
Ian.
Fwiiw, I prefer the R format. I dig out a lot of holes with two semi-circles:
Starting at X0 Y0:
G02 X2 Y0 R1
G02 X0 Y0 R1
Usually with Z spiralling downwards.
Ian - feel free to email me direct if you need more help.
Cheers
Roger
Hi....sounds interesting....I'll add it to my notes......just gotta fathom out what the code values represent.
Can you expand on that code with values for a real hole size....just the circular interpolation part.......say if you want to make a 20mm diam hole with a 10mm diam cutter.....what would the code look like and where does the Z value for spiralling down occur...........I assume you would go to the next line with G01 and a Z depth value with a feed rate?
I'm looking to see where the code values change as it creates the two semi circles to get the bigger hole size you want from a smaller cutter diam.......that would definitely be a boon for bigger holes than using a boring head.
Ian.
Hi Ian
20mm diam hole with a 10mm diam cutter... and 10 mm deep with a 1 mm cut, centred on X=15 Y=25
#1=10.00 % 10 mm deep
#2=fup[#1/1.0] % number of 1 mm passes needed
#3=[10.0/#2] % depth of each pass
% to be sure, you could skip most of this, until you want a hole 5.28 mm deep ...
#4=0.0 % Z start
#5=[20.0/2-10.0/2] % radius of cutter circle needed (do the maths)
g0 z20
g0 x15 y25 % circle centre
g0 x[15+#5] y25 % one side of circle
g0 z#4
m98 p10 L#2 % cut N circles while ramping down
g0 z20
m30
o10
#4=[#4-#3/2] % target Z half a step down
g2 x[15-#5] y25 z#4 % cut a descending semicircle
#4=[#4-#3/2] % ditto
g2 x[15+#5] y25 z#4 % ditto
m99
Load this into Mach and look at the cutter path, and study.
Cheers
Roger
Hi Rog....the format you showed is a puzzle to me.....not what I'm used to with straight G code........at the moment I'm making room in the garage by Ebaying and sorting out the junk to sell on Ebay, so no time to go to Mach 3 for the present.
Ian.
Hi Ian
It is NIST standard g-code, but CAM programs never produce anything like it. They can't: they don't have the intelligence.,
Cheers
Roger
AAAAhhhhgghhh.........now I'm completely lost, I'll stick to simple hand written G code as I am making some sense of going around in circles now......helical interpolation and thread milling looks interesting and the CNC cookbook has a tutorial to achieve it.
Just to digress off topic for a moment.......just been on EBAY and bought a couple of ER11 chucks with some collets sets too.
The chucks are the type with a plain back and an 8mm hole to mount on a motor shaft, as in the high speed water cooled spindles on the CNC routers etc.
The point is, the body is 16mm diam, 37mm total length and that makes it suitable to hold in a 16mm collet in the ER32 chucks I have on my mill and is more compact than a drill chuck.
This makes it suitable with the small extra stick out length to hold small diam drills, as a 2mm drill in an ER32 chuck is lost when it gets down to ground level.
Reason?.......well the chuck cost $7 and a set of 13 collets cost $12,.....(a small 6mm keyless chuck cost $45)....... and that makes it good to hold drills up to 7mm diam and very accurately too compared to the small drill chucks that seem to run out.
I've gone off thinking in terms of drill chucks for drill holding for now.
This happens to coincide with a drill job I'm planning to do on the mill and the G code to do it.......there will be four 5mm holes in line on a block approx. 75mm long, and there being 9 blocks that makes quite a few drill cycles to write up..
Ian. .
I do have a 0 - 3 mm chuck on a 15 mm shank for real small drill bits, but the bigger use of such a chuck is that I can get into smaller spaces with it, compared to a full-sized ER32 or ER25 collet face.
As for there being 9 blocks: that is what subroutine calls are for, along with an origin shift each time.
Cheers
Roger
Hi, a sub routine is not needed as this is a one off job and the separate blocks will just be located in the vice one at a time.
It's a simple operation, 4 holes in line etc, first to spot and chamfer the position on all blocks, then change over tools and repeat the sequence for the second tap drill size.
I think that simplifies the coding by repositioning the blocks against a stop each time..
I'm puzzling out the Gcode solution for a hole you posted in post #15......you stated that it was done with 2 semi circles.
Starting with the tool on X0 Y0....
G02 X2 Y0 R1
G02 X0 Y0 R1
Can you elaborate on how the 2 semi circles occur with this code sequence.....I can only imagine how a corner radius is formed when a 1/4 circle is coded.
Ian.
Hi Ian
N1 G02 X2 Y0 R1
N2 G02 X0 Y0 R1
N1 describes an arc starting at 0,0 and going to 2,0 with a radius of 1 in the CW direction. It's an upwards bump with a centre at 1,0
N2 describes an arc starting at 2,0 and going to 0,0 with a radius of 1 in the CW direction. It's an underneath bump with the same centre.
Stick it into Mach and look at the tool path. Run in simulation mode to see it happen.
Cheers
Roger
