Need Help! G-Code help
Results 1 to 6 of 6
Thread: G-Code help
    Registered itolond's Avatar
    Jul 2013
    Default G-Code help
    Hi Forum,
    Scenario: (Hobbyist)
    Solidworks -> Camworks - Post processor -> G-code- Mach3 (Sherline 2010 mill)
    Have an issue and really not sure how to approach the problem and thus remedy - so in simple terms stuck.
    I have attached a few files:
    1. G-code in question
    2. Error codes from Mach 3 on loading
    3. Post processor 4SCW
    anyone who can give me some guide / help would be gleefully and gracefully estatic.
    Attached Thumbnails Attached Thumbnails G-Code help-sherline-g-code-pdf
    Attached Files Attached Files
    Member KH0UJ's Avatar
    Jul 2016
    Philippines
    Default Re: G-Code help
    Does`nt run on my MACH 3 either, though it runs on my simulator but too many error codes...
    G-Code help-1-jpg
    Your codes are too simple to recreate using a custom CAM though, I dont know how you code it sir, it says bad character used line2 on my MACH 3
    Jul 2013
    Hi
    the is output from CamWorks for SolidWorks - no changes- theoretically with an operational post processor there should be no errors
    Jan 2005
    first, there are lines that actually have 2 lines together. Like this line
    N6 G40 G90N11 (16MM 60 DEG CARB CENTERDRILL)
    Should be
    N6 G40 G90
    N11 (16MM 60 DEG CAR CENTERDRILL)
    The second thing is that you have drilling cycles that you don't cancel before changing tools
    Jul 2013
    Quote Originally Posted by 109jb View Post
    Should be
    N6 G40 G90
    so I understand - the format should be 2 lines, this, as I understand is a Fanuc Generic based post processor
    I am recreating the post processor tonight to see if this helps
    excuse my lack of understanding - you mean M6 for tool change?
    Jul 2013
    ok I have progressed- crash course in to G-code
    modified line break from post processor for G80 - alas no errors.
G-Code help
G-Code help
