Apparently it's not liking one of the decimals in one of the variables in the canned cycle.
See if it runs this way?
G71 P100 Q101 DO5OO U0200 W0200 F0100
You need a G1 in the N100 line.
I don't understand the Z-.105 move. Is it a typo?
Brent
Trying to start using G71 multi-repetitive cycle on Puma 8HC turning center.
This is simple code I am trying:
When the G71 line is executed I get alarm: "Illegal use of decimal point"Code:G20 G90 M17 G28 U0. W0. T0600 S600 M42 G50 S2000 G57 M03 (TURNING TOOL #6) G0 X2.2 Z.2 T0606 (TOOL CLEAR OF PART) G96 G99 G71 P100 Q101 D.05 U.02 W.02 F.010 N100 X.5 Z0.0 X0.7 Z-.45 Z-.105 X1.25 G03 X1.75 Z-1.55 R.5 G01 Z-2.5 N101 X2.2 M05 M30 %
Can anyone tell me what I am doing wrong?
Cheers,
Steve E
- Problem Fanuc 18-T
- Need Help!- FANUC 11M-A problem
- PMC problem with Fanuc 18i TB
- Need Help!- Problem with fanuc 01
- Fanuc 6T problem
Brent
Try
G71 P100 Q101 D05 U.02 W.02 F.010
If that doesnt work try taking the point out on feed
If you send me your email I'll send you the manual
My control did NOT like decimal point for the 'Dxx' parameter. I had to use 'D0500' for a .050" deep rough pass.
Here is my working code:
Thanks for the guidance.G20 G90 M17
M42
G50 S2000
G57
(TURNING TOOL #6)
G0 X2.2 Z.2 T0606
G96 G99
M03
G01 U0. W0. F0.01
G71 P100 Q101 U0.01 W0.010 F0.01 D0500
N100 G01 X.5 Z0.0 F0.005
X1.0 Z-.45
Z-1.05
X1.25
G01 Z-2.0
N101 X2.2
G70 P100 Q101
M05
M30
Cheers,
Steve E
