Newbie faster feed rate = more gcode lines?? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: faster feed rate = more gcode lines??
  1. #21
    Member mactec54's Avatar
    Jan 2005
    Default Re: faster feed rate = more gcode lines??
    Quote Originally Posted by a3dcreator View Post
    here are the 2 gcode files.
    "contourTest2.txt" is the one that produces these artifacts.
    "contourTest3.txt" is the one that actually works. (i added more gcode lines in this one. also does not have feedrate on every line.)
    All your G-code has linear moves so there is no chance that the control can do curved or round corners, it will just cut straight lines as it has been programed G1 are linear moves
    You need a real cam program then you will be able to achieve what you are trying to do, if you have steppers then you won't be able to cut at those speeds, unless you have servos with high resolution encoders
    Mactec54
  2. #22
    Jan 2005
    a3dcerator
    Run this to see how your machine is running, it's in inches but the G20 will take care of that if your machine is setup in metric
    The dot is the X0Y0 point, this is just a test and has lots of curves, it may be to fast at 60 IPM
    Attached Thumbnails Attached Thumbnails faster feed rate = more gcode lines??-frame-zone-png
    Attached Files Attached Files
    Mactec54
