1/4 NPT External thread program
Results 1 to 6 of 6
Thread: 1/4 NPT External thread program
    Sep 2005
    Default 1/4 NPT External thread program
    Can someone help me with programming 1/4 npt external using G76 (fanuc O-T). I do not know what values to put in for the thread dimensions. Thanks!
    Member CNCRim's Avatar
    Feb 2006
    .54 dia start point with 1.75deg per side. Is it help.
    Mar 2007
    United States of America
    I'm threading 1/4 npt threads on a fanuc ot controled cnc lathe. Can anyone give me some help on the second line of info using G76?
    Jul 2005
    Lead is 18 threads per inch, taper is 0.0625" per inch diameter measure, finish diameter is around 0.56", length is around 1/2".
    May 2007
    Thread ending point figured at center of 16ER 18 NPT insert and L4 dimension from Machinery's Handbook.
    Finish turn .016R insert
    X.3768Z0
    G3X.4065Z-.0062R.021
    G1X.5249Z-.0653
    X.54Z-.3077
    Z-?
    Finish turn .031R insert
    X.3468Z0
    G3X.3977Z-.0105R.036
    G1X.5245Z-.0739
    X.54Z-.3224
    Z-?
    Thread 1/4-18 NPT external
    X.58Z.3
    G76P000155Q30
    G76X.467Z-.634P444Q150R-.0291F.05556
    Changing starting point or ending point will require R to be modified. R=tan(1+47/60)*(start point + end point) unless both points are the same sign, in which case you would subtract them.
    Single block G76
    X.58Z.3
    G76X.467Z-.634I-.0291K.0444D150F.0556A50.
    Did one of these work okay for you?
    May 2007
    Apparently my examples didn't work. What did you finally wind up with?
