tried your suggestion same results i'm sure i must be missin g something is it possible because the tool comp is not turned on? or does it not apply in this case?
maybe try to put the g19 in its own line before the g2?...
Please post a drawing, will try to code something for you.
Jeff
That was a code I copied off this thread of discussion.I see there is no height offset callup.here is how I would have written it.I am assuming those generic motions are what your looking for.this goes to tool centerline.
G17 G40 g80
T3 mo6
G0 g90 g54 x8.0 y-3.25 s1550 m03
G43 h03 z1.0
Z.1
G01 z-1.875 f25.0
X-8.0 f7.0
G19
G02 y3.25 j3.25 k-2.9375
G01 x8.0
G03 y-3.25 j-3.25 k-2.9375
G01 x7.87
G0 z10.
this is just a rectangle 16"x7" this program works fine right up to the radius cut stops with the rad error the pc is 9.625 round which im trying to cut the plate out of there is a picture with the chalk line of whats coming out on the 2nd page of this thread
thanks
G17 G20 G40 G80
G90 G54
M6 T3*
M3 S1550*
G0 X8. Y-3.25
G0 Z0 1. M08
G90 G0 X8. Y-3.25 Z-1.875 F5.
G1 X-8. Y-3.25 F20.
G2 G19 y3.25 J3.25 K-2.9375
G1 G17 X8. Y3.25
G3 G19 y-3.25 J--3.25 K-2.9375
G1 G17 X7.87
G0 Z10. M9
G0 G40 X0 Y3.5
G91 G28 Z0.
G91 G28 Y0.
G90
M30
- - - Updated - - -
tried this it would not even start cutting
THIS IS HOW I'D DO IT :
G17 G20 G40 G80
G90 G54
M6 T3
M3 S1550
G0 Z0.8 M08
G90 G0 X8. Y-3.25
Z-0.875 F5. (REMOVED 'D2')
G1 G41 D2 X-8. Y-3.25 (ADDED 'D2')
G19 (ADDED)
G2 Y3.25 R4.8125 (REMOVED 'G1' - CONFLICT WITH 'G2' - REMOVED 'Y-3.25) ( I THINK IT SHOULD BE 'G3')(MAYBE MISSING 'Z' ON ABOVE LINE ???)
G17
G1 X8. Y3.25
G2 Y-3.25 R4.8125 (SAME AS ABOVE NOTES )
G17
G1X7.87
G0 Z10. M9
G0 G40 X0 Y3.5
G91 G28 Z0.
G91 G28 Y0.
G90
M30
Joe Elson - Engineering
email: jelson@monitorsinmotion.com
METALCARPENTER IS CORRECT :
Use g19 to arc in yz axis.use ijk when programming radius is my suggestion not R...trust me.k is center of arc in
Z axis, j is center of arc in y axis.
sorry i have been super busy i have tried this latest code i get illegal address at the first arc, this seems alot more complicated than it should be is it possible im doing something wrong i really apprecate everyones help i have treied using G2 and G3 same problem Thanks Guys
