Need Help!- G84 tapping on the sub spindle XP4-42SM Quick-Tech Syntec Control
Hi Folks,
I'm having trouble getting our sub spindle to do a tapping cycle. Is there a different Canned Cycle for the Sub Spindle?
The part is simple. It's a 1/8" dia rod, 3.3" long, with a 5-32 thread on one end, and a 5-40 thread on the other. I'm trying to roll a 5-40 thread on the Sub Spindle end.
This is what I have for code now on the front, which works fine:
N1040 T0808; //TOOL 8 CALL UP//
N1050 G97 S1000 M03; //CSS OFF - 1000 RPM//
N1060 G18; //XZ PLANE//
N1070 G00 G95 Z.5 M08; //FEED PER REV//
N1080 X0.0; //RAPID TO X0//
N1090 Z.2; //RAPID UP TO Z AXIS START POSITION//
N1100 G84 X0.0 Y0.0 Z-.75 P1.0 F.03125; //TAPPING CYCLE 5-32 THREAD//
N1110 G80 G00 Z.2; //BACK TO .2 OFF MATERIAL//
N1120 M05; //SPINDLE STOP//
This is what I'm trying on the sub spindle, which is not working:
N1400 T1919; //CALL UP TOOL 19 SUB SPINDLE 5-40//
N1405 G00 G54 X0.0;
N1410 M182; //LOOK SUB SPINDLE FOR FEED RATE CONTROL//
N1420 G97 S2=1000 M203; //**M203**CSS CANCEL - SUB SPINDLE 1000 RPM CLOCKWISE//
N1430 G00 G95 M28; //FEED PER REV - Z AXIS START LOCATION - COOLANT ON//
N1440 Z-.2;
N1450 G84 X0.0 Y0.0 Z.44 P1.0 F.025; //SUB SPINDLE TAPPING CYCLE AT 40 TPI// /
N1460 G80 G00 Z-.2; //BACK TO .2 OFF MATERIAL//
Can anyone help me out?
Kevin Similar Threads:
Re: G84 tapping on the sub spindle XP4-42SM Quick-Tech Syntec Control
N10; //KB1015 WITH G284 10-08-2014 AT 1:00 PM//
/N20 M98 P1000;
N20 G90 G95;
N30 T5050; //STOCK STOP USE SIDE OF CUTOFF//
N40 G00 X0.0;
N50 Z0.0;
N60 M11; //MAIN SPINDLE COLLET OPEN//
N70 M20; //BARFEEDER ON //
N80 G04 X2.; //TIME FOR FEED OR BAR FEEDER END SIGNAL//
N90 M21; // FEEDER OFF //
M10;
G4X.2;
N91 Z.5;
N92 G28 U0;
N93 Z-3.3;
N95 G70; //OUTPUT IN ABSOLUTE INCHES//
N100 G00 G90 G53 Z1=0.0; //MACHINE COORDINATE SYSTEM SETTING//
N120 M53; //SYNC MAIN AND SUB//
N120 G97 S2500 M03 S2500 M203; //CSS CANCEL - S2500 SUB SPINDLE CW//
N140 M61; //SUB SPINDLE CHUCK OPEN//
N150 G00 Z1=.5; //RAPID UP TO .5 BEFORE PART//
N160 M22; //MAIN SPINDLE AINR BLOW ON//
N170 G94 G01 Z1=-2.0 F20.0; //FEED PER MINUTE//
N180 G04 X.5; //DWELL//
N190 M60; //SUB SPINDLE CLOSE//
N200 M23; //MAIN SPINDLE AINR BLOW OFF//
N210 G04 X.5; //DWELL//
N300 T0101; //CUT OFF AND CHAMFER TOOL//
N310 M05; //C AXIS SERVO OFF//
N320 M181; //LOOK TO MAIN SPINDLE FOR FEED RATE//
N330 M53; //SYNCHRONINZE MAIN AND SUB//
N340 G92 S3000; //MAX SPINDLE SPEED SETTING//
N350 G97 S2500 M03 S2=2500 M203; //CSS CANCEL - MAIN AND SUB AT 2500 RPM//
N360 G18; //ZX PLANE SELECTINON//
N370 G00 G95 G90 Z-3.1895 M08; //FEED PER REV - POSITION//
N380 X.526; //RAPID TO X TOOL START POSITION//
N390 G01 X.5253 F.0007; //START X FEED//
N400 G96 S200; //CSS CONTROL 200 SFM//
N410 G01 X.214; //FEED IN TO X START POSITION//
N420 X.1246 Z-3.2789; //FEED IN X AND Z AXIS TO TURN CHAMFER//
N430 X.105 Z-3.2985; //FEED OUT IN X AND Z AXIS TO TURN CHAMFER//
N440 X.5253 F.2; //FEED OFF MATERIAL IN X AXIS//
N450 Z-3.4085; //FEED TO Z START POSITION FOR BACK CHAMFER//
N460 G01 X.214 F.0007; //FEED IN TO X AXIS START POSITION//
N470 X.1246 Z-3.3191; //FEED IN TO START CHAMFER//
N480 X.105 Z-3.2995; //FEED IN X AND Z AXIS TO TURN BACK CHAMFER//
N490 Z-3.2985; //FEED AWAY IN Z .0011//
N500 X.5 F.2; //FEED AWAY FROM MATERIAL TO CUT OFF START LOCATION//
N580 G00 G95 Z-3.3 M08; //FEED PER REV//
N590 G01 X.2055 F.0007; //FEED IN TO TOOL START POSITION//
N600 G42 X.1055; //FEED IN TO MATERIAL WINTH OFFSET COMP ON RIGHT//
N610 X-.004; //FEED IN TO CUT OFF MATERIAL//
N620 G40 X-.104; //FEED BEYOND CETER//
N630 G01 X.5; //FEED OFF OF MATERIAL//
N640 G97 S2500; //CSS OFF - 2500 RPM//
N660 G00 G90 G53 Z1=0.0; //RAPID SUB SPINDLE BACK//
N670 G28 U0.; //X AXIS HOME//
N680 ;//G28 W0. //Z AXIS HOME//
N690 M09; //MAIN SPINDLE COOLANT OFF//
N700 M54; //SYNCH MAIN AND SUB OFF//
N710 M05; //MAIN AND SUB ORIENTATION CANCEL//
N720 M205; //SUB SPINDLE STOP - SUB ORIENTATION CANCEL//
//SECOND FEED OUT//
/N721 M98 P1000;
N722 G90 G95;//**WAS G94**//
N723 T5050; //STOCK STOP USE SIDE OF CUTOFF//
N724 G0 G57 Z1.0;//**MADE Z 1.0** Z0 //WORK SHIFT TO G57//
N725 G90 G00 X0.0; //RAPID TO X LOCATION FOR FEED OUT//
G00 Z.5; //RAPID TO APPROACH STOCK STOP IN Z AXIS//
G01 G94 Z0.0 F5.; //FEED UP TO FEED OUT POSITION//
N726 M11; //MAIN SPINDLE COLLET OPEN//
N727 M20; //BARFEEDER ON //
N728 G04 X2.; //TIME FOR FEED OR BAR FEEDER END SIGNAL//
N729 M21; //FEEDER OFF//
M10;
G4X.2;
N730Z.5; //RAPID AWAY FROM MATERIAL .500//
N740G28 U0; //SEND HOME IN X AXIS//
N750 M01; //OPTIONAL STOP//
N830 T1010; //BOX TOOL//
N840 G97 S2500 M03; //CSS CANCEL//
N850 G18; //XZ PLANE//
N860 G00 G95 Z.5 M08; //FEED PER REV//
N870 X0.0; //RAPID TO X0//
N880 Z.2; //RAPID TO Z START POSITION//
N890 G01 Z-.75 F.003; //FEED BOX TOOL ONTO BAR END .750//
N900 G0 Z1.; //RAPID BACK TO TOOL CHAGE POSITION IN Z AXIS//
N920 G28 U0.; //X AXIS HOME//
N930 ;//G28 W0. //Z AXIS HOME//
N940 M09; //MAIN SPINDLE COOLANT OFF//
N950 M05; //MAIN SPINDLE STOP//
N960 M01; //OPTIONAL STOP//
N1050 G97 S2000 M03; //CSS OFF - 2000 RPM//
N1070 G00 G94 Z.5 M08; //FEED PER REV//
N1100 G84 X0.0 Y0.0 Z-.75 P10.0 F62.5; //TAPPING CYCLE 5-32 THREAD//
N1140 Z1.; //RAPID OUT TO TOOL CHAGE POSITION//
N1150 M05; //MAIN SPINDLE STOP//
N1180 G28 U0.; //X AXIS HOME//
N1190 ;//G28 W0. //Z AXIS HOME//
N1200 M09; //MAIN SPINDLE COOLANT OFF//
N1210 M01; //OPTIONAL STOP//
//BACK END WORK//
N1290 T2020; //CALL UP TOOL 20 BACK SPINDLE HOLLOW MILL//
N1300 M182; //LOOK TO SUB SPINDLE FOR FEED RATE CONTROL//
N1310 G97 S2=2500 M204; //**M204**CSS CANCEL - SUB SPINDLE 2500 RPM CLOCKWISE//
N1320 G18; //ZX PLANE//
N1325 G54;
N1330 G00 G95 Z-1.0 M08; //FEED PER REV - RAPID TO TOOL START POSITION//
N1340 X0.0; //RAPID TO X AXIS POSITION//
N1350 Z-.25; //RAPID APPROACH TO Z START POSITION//
N1360 G01 Z.44 F.003; //FEED INTO PART TO TURN DIAMETER TO .107 DIA//
N1370 G00 Z-1.; //RAPID OFF OF PART//
N1380 G28 U0.; //X AXIS HOME//
N1390 ;//G28 W0. //Z AXIS HOME//
N1400 T1919; //CALL UP TOOL 19 BACK SPINDLE HOLLOW MILL//
N1405 G00 G54 X0;
N1410 M182; //LOOK TO SUB SPINDLE FOR FEED RATE CONTROL//
N1420 G97 S2=1000 M204; //**M204**CSS CANCEL - SUB SPINDLE 1000 RPM CLOCKWISE//
N1430 G04 X2.; //DWELL TIME FOR SPINDLE TO SPEED UP//
N1440 G00 G95 Z-.2 M28; //FEED PER MINUTE - Z AXIS START LOCATION - COOLANT ON//
N1450 G284 X0.0 Y0.0 Z.44 R0.0 F.025 S1000; //SUB SPINDLE TAPPING CYCLE AT 40 TPI//
N1470 M205; //SUB SPINDLE STOP//
N1480;
N1490;
N1500;
N1510 G28 U0.; //X AXIS HOME//
N1520 T5050; //STOCK STOP CALL OUT//
N1525 G00 Z-2.; //**G00**Z AXIS AWAY//
N1530 M29; //COOLANT OFF//
N1540 M205; //SUB SPINDLE STOP - ORIENTATION CANCEL//
N1550 M01; //OPTIONAL STOP//
N1580 M13; //PARTS CATCHER ON//
N1590 G94 G04 X.3; //DWELL//
N1600 M01; //OPTIONAL STOP//
N1630 G56; //COORDINATE SYSTEM CALL OUT//
N1640 G00 G90 G53 Z1=-12.0; //MOVE Z1 TO PART EJECT POSITION//
N1650 M13; //PARTS CATCHER ON//
N1660 M61; //SUB SPINDLE OPEN CHUCK//
N1670 M24; //SUB SPINDLE AINR BLOW ON//
N1680 G04 X.2; //DWELL//
N1690 M25; //SUB SPINDLE AINR BLOW OFF//
N1700 G04X.2; //DWELL//
N1710 M14; //PARTS CATCHER OFF//
N1720 G00 G90 G53 Z1=0.; //RETURN SUB SPINDLE TO Z ORIGIN//
N1730 M05; //SPINDLE OFF//
N1740 M01; //OPTIONAL STOP//
N1890 G28 U0.;
N1900 ;//G28 W0.//
N1910 ;//G28 U0.V0.W0. //TOOL PLATEN AT REFERENCE HOME POINTS//
N1912 M01;
N1915 M99;
N1920 M30;
Forum Rules
