Need Help! G Code programming
Results 1 to 3 of 3
Thread: G Code programming
    Sep 2011
    india
    Default G Code programming
    Hello All,
    I need to run two parallal linear axis together at different speeds. Can anyone suggest how to command into the G Code program for the same?
    Dec 2012
    The Netherlands
    Default Re: G Code programming
    Can I ask what the reason for this is ?
    Regards,
    Heavy_Metal
    Apr 2007
    UK
    each axis would have to be called a separate axis and not just a mirror. Is that how it is wired?
G Code programming
G Code programming
