Jpeg to Gcode
Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: Jpeg to Gcode
    Feb 2004
    Default Jpeg to Gcode
    Somebody wants meto cut them a deer scene in 2 dimensions but I'm not having any luck converting a jpeg into something I can use. I tried my Mach2 but it did'nt work for me, any other suggestions? The white parts of the picture would be cut out and the black parts would remain.
    Attached Thumbnails Attached Thumbnails Jpeg to Gcode-buck-doe-enlarged-jpg   Jpeg to Gcode-buck-deer-silhouette-enlarged-jpg
    Mar 2003
    I wrote a program in Matlab that pecks a countersink bit to a depth that is proportional to the darkness (or lightness) of each pixel. I'm not sure if this is what your looking for but it gives an interesting image. I can generate g-code for the pict that you posted. You would have to tell me what length or width you'd want the end result to be.
    Tony
    xeno@xenomechanics.com
    http://www.xenomechanics.com
    Jan 2005
    Hungary
    You can use Meshcam to make gcode from a picture. It is relatively cheap (100 bucks), really easy to use, and there is a 60 day trial. www.meshcam.com
    Giorgio
    Registered MILLMANM's Avatar
    Jul 2004
    You can also use Corel trace, a raster (jpeg) to vector program (dxf) and a demo version is avalible
    and then put in it in your cam system as a dfx file
    IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH
    Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust.
    Registered Aksess's Avatar
    May 2004
    Will this do? I just converted a bmp with plasmacam to a dxf
    Attached Files Attached Files
    Oct 2005
    Egypt
    hey if any body can help I need a freeware that converts DXF files to gcode
    thnx
  7. #7
    Mar 2003
    ACE converter. www.dakeng.com
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  8. #8
    Jul 2004
    Aksses
    your drawing worked good in mastercam anyone need the g code?
    Brad
  9. #9
    May 2004
    I use plasmacam exclusivily for 2d art "cut outs" I can output as dxf or g-code even rearange toolpaths. To bad it isnt free it cost around $2500
  10. #10
    Feb 2004
    I really appreciate the replies to my question and I'm going to try some of them as soon as I get my machine running again. I turned the computer on last Saturday and it couldn't access the hard drive was the message. I tried a different hard drive but the computer still couldn't access the hard drive. Any suggestions?
  11. #11
    Nov 2005
    uk
    I'm thinking of buying either an engraver or a router... can that deer scene be cut nicely with a router?
  12. #12
    May 2004
    Yes it can be cut nicely with a router.
Jpeg to Gcode
Jpeg to Gcode
