Jpeg to Gcode
Results 1 to 20 of 20
Thread: Jpeg to Gcode
    Feb 2004
    Default Jpeg to Gcode
    Somebody wants meto cut them a deer scene in 2 dimensions but I'm not having any luck converting a jpeg into something I can use. I tried my Mach2 but it did'nt work for me, any other suggestions? The white parts of the picture would be cut out and the black parts would remain.
    Attached Thumbnails Attached Thumbnails Jpeg to Gcode-buck-doe-enlarged-jpg   Jpeg to Gcode-buck-deer-silhouette-enlarged-jpg
    Mar 2003
    I wrote a program in Matlab that pecks a countersink bit to a depth that is proportional to the darkness (or lightness) of each pixel. I'm not sure if this is what your looking for but it gives an interesting image. I can generate g-code for the pict that you posted. You would have to tell me what length or width you'd want the end result to be.
    Tony
    xeno@xenomechanics.com
    http://www.xenomechanics.com
    Jan 2005
    Hungary
    You can use Meshcam to make gcode from a picture. It is relatively cheap (100 bucks), really easy to use, and there is a 60 day trial. www.meshcam.com
    Giorgio
    Registered MILLMANM's Avatar
    Jul 2004
    You can also use Corel trace, a raster (jpeg) to vector program (dxf) and a demo version is avalible
    and then put in it in your cam system as a dfx file
    IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH
    Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust.
    Registered Aksess's Avatar
    May 2004
    Will this do? I just converted a bmp with plasmacam to a dxf
    Attached Files Attached Files
    Oct 2005
    Egypt
    hey if any body can help I need a freeware that converts DXF files to gcode
    thnx
  7. #7
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    ACE converter. www.dakeng.com
    UCCNC 2017 Screenset
  8. #8
    Jul 2004
    Aksses
    your drawing worked good in mastercam anyone need the g code?
    Brad
  9. #9
    May 2004
    I use plasmacam exclusivily for 2d art "cut outs" I can output as dxf or g-code even rearange toolpaths. To bad it isnt free it cost around $2500
  10. #10
    Feb 2004
    I really appreciate the replies to my question and I'm going to try some of them as soon as I get my machine running again. I turned the computer on last Saturday and it couldn't access the hard drive was the message. I tried a different hard drive but the computer still couldn't access the hard drive. Any suggestions?
  11. #11
    Nov 2005
    uk
    I'm thinking of buying either an engraver or a router... can that deer scene be cut nicely with a router?
  12. #12
    May 2004
    Yes it can be cut nicely with a router.
  13. #13
    Nov 2005
    uk
    I've seen examples of routing using a 0.5mm cutter... is it possible to buy/use finer cutters for routing?
  14. #14
    Mar 2003
    Shelby Township
    .01", or .254mm. You need a very good spindle with these, with little to no runout or they break easily.
    http://www.thinktink.com/cgi-bin/car...ep=20&start=19
  15. #15
    Nov 2005
    uk
    so what type of cutters are used on engraving machines for very fine line work?
  16. #16
    Mar 2003
    Shelby Township
    Quote Originally Posted by w i l l
    http://www.antaresinc.net/FactCutterGeometry.html
  17. #17
    Nov 2005
    uk
    that doesn't tell me difference between a routing cutter and an engraving cutter... can you use an engraving cutter in a router?
  18. #18
    Mar 2003
    Shelby Township
    An engraving cutter is designed to engrave. Just the tip cuts. You can use it in a router, but you can't cut parts with it. Router bits come in many different configurations, for different applications. If you're working with wood, and want to do engraving, just get a V bit like these. http://eagleamerica.com/product.asp_Q_pn_E_132-1022 The engraving cutters I linked to before work best in metals and plastics.
  19. #19
    Dec 2005
    Look on my site at http://www3.telus.net/tarkus
    look near the bottom of the page, there's a program I wrote called Picmill.
    It will take a jpeg/gif/bmp and turn it into heightmapped Gcode... in other words, it will make a psuedo-3d representation of the image... it only works with ballnose endmills currently, but it does work.
    If you just want outlines, I can post the gcode for the toolpath, just tell me how deep you want the cutter to go and how high you want it to clear the top.
    http://smackaay.com
    Visit my site
  20. #20
    Member hasanqo's Avatar
    Dec 2019
    Default Re: Jpeg to Gcode
    please can you post the program and how to resize the image to the work space.tanks
Jpeg to Gcode
Jpeg to Gcode
