Results 1 to 2 of 2
Thread: vmc 7040 enshu 1982 fanuc 6m
    Oct 2008
    Unhappy vmc 7040 enshu 1982 fanuc 6m
    Need schematic for enshu vmc-7040 fanuc 6m
    Machine just stop's running , no Alarm code and no messages screen goes blank ..
    Registered Leblondmakino's Avatar
    Oct 2007
    UK
    Hi this sounds like you're power supply has gone down...this will drop the power to the screen and control panel.
    A14B-0061-B001
    or
    A14B-0061-B002
    Check the fuses on this unit (you must remove them to check properly with a volt meter) and also your 24v DC power supply (little black box) could be a Lambda or similar make.
    John.
  1. Need Help!- ENSHU VMC40
    By RAMI in forum General Metal Working Machines
    Last Post: 07-05-2011, 11:35 PM
  2. Need Help With Enshu , schematic , 6m Fanuc
    By Rob Lacy in forum Forum Questions or Problems
    Last Post: 08-17-2009, 05:11 PM
  3. Need Help!- NEED FANUC 11M KEYPAD SUPER MAX 1982 VMC
    By JOHN PARSONS in forum Fanuc
    Last Post: 07-15-2009, 03:58 PM
  4. Need Help!- 1982 fanuc CNC CK2
    By mark oz in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 01-30-2009, 06:09 AM
  5. Problem- 1982 fanuc 6m control (Enshu) 401 servo error
    By Rob Lacy in forum Fanuc
    Last Post: 10-26-2008, 03:51 PM
