Same problem here.
My thread search menu displays lines of:
undefinedundefinedundefined....
Hard to figure out what the thread is about.
The link still works, but garbage as above displayed in the scrollable menu.
Clearing cache and resetting all java stuff doesn't fixit.
Forums on other sites using the same format/engine work.
Only this site.
Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Same problem here.
Software For Metalworking
http://closetolerancesoftware.com
I have NO idea what you are talking about, can you give a bit more info?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
This is what I currently see with threaded display mode turned on. It was fine until a month or two ago - then changed for some reason.
OK I see, I'm working on fixing it.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
I have looked at the java stuff in the file.
It looks like the text is there, but therr is a problem displaying it.
Two problems in error log. (using firefox)
Java stuff:
lighbox.css:
filter:alpha(opacity=40); It hicupped on this,
display: inline-block; and this.
Regards.
Neil.
