Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Zone Search Engine Logic Query
    Registered derekj308's Avatar
    Jun 2005
    Hi
    The zone search engine does not any return results for 'G52'.
    I started this post because I couldn't find it
    G52 Used For Patterning
    but if you do a google search as Switcher has shown
    http://www.google.com.au/search?hl=e...e+Search&meta=
    The engine will find 'Mach2' but wont find 'G52', 'G3', 'G1'.
    Am I using the search incorrectly?
    If not can someone please check the logic in the search engine that is causing these strings to not be found.
    Derek
    <insert witty comment here>
    derekj308
    Gold Member widgitmaster's Avatar
    Jun 2005
    In your post you used single quotes, is that what you used in the search?
    All search engines recognize double quotes as a means of designating and forcing a boolean AND logic condition, the single quotes would be looked for as an exact character match - an unlikely found condition!
    Eric
    Jul 2005
    Curioser and curioser.
    I took Eric's comments and searched 'G52'. This found one thread, this one! So on the search results page I clicked on the link to this thread and the system denied me access from that direction.
    Jun 2005
    Hi Eric
    No I didn't use the single quotes just G52. I think I tried "G52" as well (actually using the double quotes) and also returned nothing. I'll check now.
    Cheers
    Derek
    derekj308
    Jun 2005
    Yep "G52" also returns nothing.
    derekj308
    Jun 2005
    I would also like to suggest that your searching results my be affected by which ever language your computer is set up for, as this also modifies the character map used by your computer to interface with the world!
    Eric
    Moderator Switcher's Avatar
    Apr 2005
    mydxf.blogspot.com
    I'll show you a little trick on how to get more results from a specific site like "cnczone" with the help of Google. I have 3 parts to my search:
    1) G52 = (search subject)
    2) site: = (tell Google to only search a specific site, & nothing else on the web)
    3) www.cnczone.com = (whatever specific website I want to do my search on)
    Now I add all 3 to create my search " G52 site:www.cnczone.com " enter this in the Google search.
    That will return this, http://www.google.com/search?sourcei...ecnczone%2ecom
    You can do this on any website on the net, just change the site name.
    Just remember that only pages that have been crawled by Google will end up in your search results, like this post wouldn't be returned just after I post (hasn't been crawled since my posting) might take a day or two, or a few min. you never know.
    Apr 2005
    mydxf.blogspot.com
    No offense to the cnczone search engine (or any other search engine).
    NO search engine can hang with Google!
    Site Owner CNCadmin's Avatar
    Mar 2003
    On the top of every page is a google search box for cnczone.
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Jul 2005
    Quote Originally Posted by CNCadmin View Post
    True but surely the CNCzone internal search should find terms such as G52. I have tried a few terms and it seems to not find terms with fewer than four characters. As someone mentioned it finds mach2.
    In addition how come when I do a search and then try to use the search results to link to the page that is found it denies me access?
    Mar 2003
    try it now
    Thank You,
    Paul G
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Jul 2005
    try it now
    Thank you, now I no longer feel excluded .
  • Page 1 of 2 12 LastLast
