The file is:
Code:
Cookie:(Whatever User is logged in)@www.cnc.zone
Go to "Temporary Internet Files", Delete everything except Code:
Close all open windows, re-open www.cnczone.com, you should still be logged in.
Now, go back to "Temporary Internet Files", and Delete everything, close all windows, re-open www.cnczone.com, you should NOT be logged in.
You can also go to "Temporary Internet Files", copy the Code:
cookie to your desktop, open the file with Notepad, and look for your (cnczone) "User ID" number, look for "bbuserid#####".
If you want verify that number, do this. Go to www.cnczone.com, find a post that you wrote, put your cursor over your user name, it will show you at the bottom of the screen your user number.
vladdy, your user number is "2850", which should also be the same unique number in your cookie "bbuserid2850".
Also, If you don't close out the browser, and you delete the cookie, then you go on in the browser to a new page, it will re-write the cookie without you needing to login again, you can check that in the "Temporary Internet Files" (Last Modified),
The bottom line is, you need the cookie, to stay logged in, also the cookie expires exactly one year from your last login.
