Results 1 to 5 of 5
Thread: Reading Order of Threads
    Apr 2009
    I'm trying to figure out why some threads read top down and some read bottom up. Can someone enlighten me?
    Apr 2010
    Probably depends on whether you're signed in or not.
    Under UserCP (control panel) you can set the option that applies when you are signed in.
    Apr 2009
    I'm not seeing this option under CP. Can you tell me which one it is?
    Apr 2010
    Click UserCP
    The left column is labelled "Your Control Panel"
    Look down under "Settings & Options"
    Click on "Edit Options"
    In the center column now there is a heading called "Thread Display Options"
    Under that is "Thread Display Mode" with a drop-down menu.
    Click on the drop-down and select your setting.
    Apr 2009
    Thanks for your help. That fixed it.
    1. Reading threads
      By redyute in forum Forum Questions or Problems
      Last Post: 09-25-2011, 04:56 PM
    2. T.I.R. reading help
      By flashbang in forum Benchtop Machines
      Last Post: 07-19-2010, 06:37 PM
    3. Reading the Mem Card
      By esadaddy in forum Fanuc
      Last Post: 01-17-2009, 10:30 PM
    4. How to format threads order?
      By wizardrule in forum Forum Questions or Problems
      Last Post: 10-07-2008, 03:18 PM
    5. Saving threads or parts of threads???
      By flybynight in forum Forum Questions or Problems
      Last Post: 02-22-2004, 01:19 AM
