Results 1 to 4 of 4
Thread: ACRAMATIC 2100 CONTROL
    Oct 2008
    I HAVE A CINCINNATI MILACRON VMC 750 WITH A ACRAMATIC 2100 CONTROL WITH A TOUCH SCREEN . I AM TOLD THAT I HAVE A BAD VIDEO CARD. THE CPU HAS A PLACE FOR A STANDARD VGA MONITOR BUT WHEN I PLUG IT IN NOTHING HAPPENS. CAN ANYBODY HELP ME WITH THIS PROBLEM. I WAS ALSO TOLD I COULDN'T FIND A NEW OR REPAIRED VIDEO CARD. WHEN IT BOOTS IT RUNS THRU CMOS AND THEN IT COMES UP TO A DARK BLUE SCREEN WITH LINES AND A SMALL BLACK BOX IN THE MIDDLE. PLEASE HELP. I NEED THIS MACHINE BAD.
    May 2006
    mexico
    Hi natedog,
    I have experienced the same problem few years back, with one of our machines an ARROW 750 ,
    First, remove your damaged video card ,
    If you connect a standard monitor in the CPU you should be able to see the image , bigger than normal but it works ,
    Oct 2008
    Thanks CNCATJ,
    That got me over the first hump. Now when the machine boots I get a error message that says "mustang\system\sy981117\exe\msg.dll" process terminated abnormally APM.EXE. It also doesn't pass my nc startup. Any help would be appreciated.
    May 2006
    mexico
    Sounds like a software problem ,
    Does this machine was working all good before ?
    I would call Dave Lyle @ siemens , he will point you in the right direction
  1. siemens acramatic 2100 control
    By jptalon in forum Siemens Sinumerik CNC controls
    Last Post: 09-19-2012, 07:00 AM
  2. acramatic 2100 control
    By reyes882 in forum Cincinnati CNC
    Last Post: 08-25-2009, 05:51 AM
  3. acramatic 2100 control
    By greg b in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 06-01-2009, 04:33 PM
  4. Acramatic 2100 control Help
    By fmprap in forum Cincinnati CNC
    Last Post: 01-05-2009, 04:47 PM
  5. Acramatic 2100 control parts
    By VSMIGuy in forum General Metal Working Machines
    Last Post: 02-19-2007, 02:23 PM
