Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines > Foam Cutting Software
Foam Cutting Software Discuss Foam cutting software here.
Old 11-07-2009, 02:57 PM
rjfurness@bigpo is on a distinguished road
New Profili Software
Hello Anyone,
there is a new version (2.24) of Profili software with a specific function to directly cut wing cores. It looks clear and simple. I am wondering if anyone has used it.
What are your opinions?
Jason
Old 11-10-2009, 12:47 AM
iflyrctoo is on a distinguished road
I've just started using Profili Pro 2.24.... It doesn't directly control your machine but will output dxf or dat files that can be used with GMFC or Foamworks to cut foam. It has a 3D foam cutting simulator built in and a nice database of airfoils available. Lots of options but you will need to register it to use the print or file export functions.
Old 11-10-2009, 04:22 AM
Thanks for clarifying that. I was understanding it directly controlled the CNC itself.
Jason
Old 03-22-2010, 01:03 PM
HaoleboyRC is on a distinguished road
Export files to FoamWorks
I have Profili Pro and my flying buddy has a CNC foam cutting table and took a couple of dat files with me but could not import them into FoamWorks. Does anyone know how to do that and could you please advise. We had to rebuild the wing planform on foam works to do the cutting. What output format from Profili will work in Foam Works
Need Help!- About the software harm CNC Machining Centers 7 11-24-2009 08:30 AM
TL1 New Software redsid66 Haas Lathes 4 04-15-2009 04:32 PM
Just IN- MIE Solutions - Free Quoting Software Trial Software available MIE Solutions Product Announcements & Manufacturer News 0 01-07-2009 11:42 AM
First post in the software dept. Free cnc software? runinbymdnt General CNC (Mill and Lathe) Control Software (NC) 2 02-06-2007 10:49 PM
