Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines > Foam Cutting Software
Foam Cutting Software Discuss Foam cutting software here.
Old 08-06-2009, 11:25 PM
signtrainer is on a distinguished road
Need Foam Cut Software Suggestion
I am looking for software to use with my HOBBYCNC board that is friendly toward LETTERS & NUMBERS. I will not be making wings. Just signs.
So far I do not see any that really address Alphanumerics well.
Does anyone know an answer to this??
Richard / ask@signtrainer.com
Old 10-19-2010, 08:59 AM
Mediespecialist is on a distinguished road
Hi. I have had the same question that you have and here is what I use today:
Corel Draw, for making my graphics, letters and toolpath.
Deskcnc, to convert HPGL files to DXF and making G-code.
Mach3 for controlling my 2 axis machine.
/ Petter
Old 05-14-2011, 01:20 PM
vtcnc is on a distinguished road
Not sure, but you might check out the Foamworks 4.0 -- it outputs G-code instead of being a stepper driver, and I believe it is not strictly wing oriented.
Old 01-02-2012, 01:20 PM
blake374 is on a distinguished road
Hello
I am interesed in using my 4 axis foam cutter to make letters and numbers. I am curently using A CAD program to make numbers and letters, Desk CNC to make the G code and mach3 to run the machine. The numbers and letters all come out with flat spots on the curves.
Can anyone tell me about using correl draw in this process. How do you make a tool path using Corel draw. I use Desk CNC for this. Do you mean that you draw the out line of the letters using corel draw and make actual tool path in Desk CNC.
Need Help!- Need suggestion what software or cam or ??? to use with lathe/turntable DanOSB CNC Wire Foam Cutter Machines 4 02-06-2009 01:49 AM
Foam Cutting Software Mcyoda CNC Wire Foam Cutter Machines 0 08-22-2008 11:42 PM
Cam software suggestion fidia General CNC (Mill and Lathe) Control Software (NC) 0 12-09-2007 10:56 AM
Hello, I need suggestion on getting 4 axis CNC as well as software to do few things. jinu117 Benchtop Machines 17 07-16-2006 06:40 AM
Good Foam Cutter CAM Software? vacpress General CAM Discussion 0 03-30-2004 06:26 PM
