after building a big CNC wood router, I now turn to a foam cutter that can cut foam wings for my model planes. Mechanical the machine is simple: two 2D moving carts, on threaded bar. The distance between the carts I can alter so the distance equals the length of the wing, so to speak. I've constructed a wire tensioner that keeps the tension equal at all times, using some pulies and weights. Now I've been reading alot about software, but it's not my strong point, and I want to be sure I get the right stuff.
Now for the software bit;
I design the tip airfoil and the root airfoil in AutoCAD. I don't only cut the outside contour, but also chambers and for instance an opening for a carbon tube. And that's where the trouble starts, I think. If the tip is just a centain percentage of the root, the cutting speed will be an equal percentage. But cutting the tube-hole, there will be speed variations. Getting from the contour-cut to the hole-starting-point will be a different size at tip and root, but cutting the hole should be equal at both sides, so the cutting speed should be equal too, not a percentage. Also, the hole might be located at 1/3 of the wing-width at the root, but at 1/2 of the length of the tip. I think I need software that accepts me giving it 'synchronisation points'. I hope you understand, English is not my first language and getting into these technical details isn't easy...
Please help me pick the right bits and bytes,
Cheers,
Hugo
Haven't tried it -- yet, but Profili 2 might be an answer.
The website says it will do what you're looking for:
http://www.profili2.com/eng/pannelli_pol.htm
OOPS _ SORRY 'Bout that - seems that Profili won't generate Gcode - or doesn't seem too. (Had to have a load and look)
SO, maybe try JediCut - it even mentions synch-points -
http://www.aeropassion.net/index-en.php
Are you planning on the wing being cut from a single blank - or several and thats why you are looking for "sync points?"
I think most wing software would let you cut the spar location on a taper just like the planform. Seems a bit unusual though - most typically the spar is at the aerodynamic center for the entire span -- unless you have a very unusual tip profile.
Jim
Hugo - had a bit of a play with both and maybe the one you're looking for might be this one:
http://www.excelcut.netmyne.com/ Its free too! Seems you'll need an older version of Excel - He wrote this in excell/office 2003 I recall.
Profili2 won't let you export GCode, JediCut is awkward for me - not french reading to well, ExcelCut will now import a dat file - so you can get to that quickly from the various databases. And the spar can be placed as you want. Best of Luck - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
