Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines > Foam Cutting Software
Foam Cutting Software Discuss Foam cutting software here.
Old 05-19-2008, 10:58 PM
kingpav is on a distinguished road
Path Issues - Which Software???
PLEASE SEE THE ATTACHED ILLUSTRATION OF THE ISSUE.
OK as you can see from the illustration provided I have one block of foam which requires the left set of axis to cut one set of shapes (smaller) and the right set of axis to cut the other (larger) shapes.
Also note that the shapes from left to right vary as the left hand shape is square and the right hand shape is a star. Both of these have different perimeter lengths. I hear that Foamworks would have trouble with this as the number and placements of the points would vary too much and by using Foamworks it would cause the shape to be cut incorrectly. At first i thought that increasing the feed on the right hand set of axis would work but I imagine that would need some rather tricky tuning.
Sorry about the caps but just making the question clear.
SO...
WHICH SOFTWARE SHOULD I BE USING THAT WOULD ENSURE THAT BOTH PATHS ARE CUT PROPORTIONALLY? OR MAYBE ANOTHER WAY OF PUTTING IT WHICH SOFTWARE WOULD BE ABLE TO COPE WITH CUTTING ONE SHAPE ON ONE SIDE AND A CONSIDERABLY DIFFERENT SHAPE ON THE OTHER WITHOUT MAKING ANY ERRORS???
Many thanks in advance,
Paul
Name:	Both Sides.jpg‎
Motors too weak, bad ball screws or software issues?? pics of messed up parts... Mueller General Metalwork Discussion 0 07-09-2007 11:55 AM
Practical CNC software issues Eric B. CNC Plasma and Waterjet Machines 15 09-02-2006 01:05 AM
Shortest path between points? Software? jderou General CAM Discussion 2 12-22-2005 05:45 PM
Change - from linear path control to CNC path control fidibus42 General Electronics Discussion 1 12-04-2005 11:43 AM
4 Axis EDM software , used to create foam cutting path? bgriggs Foam Cutting Software 1 09-29-2005 05:52 AM
