Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: New release of CeNeCe PRO ver.: 1.10
    Jul 2005
    spain
    Hi everyone,
    Just to let you know, that the new release 1.10 of the CeNeCe PRO, is available.
    WHAT'S NEW:
    - ** Added support for DXF files with MULTIPLE shapes, the program will connect them automatically!!!!
    - Added full support for Leading Edges in profile projects, with 5 different types of LE and real time preview.
    - General performance improvement
    - Added different texts for profiles and shapes projects.
    - added checkbox in the movement screen to select if the speed should also be changed in the cutting screen
    - Rotation/washout values are now in the "cutting data" tab of the projects maintenance.
    - Longerons moved to projects maintenance (still under devellopment).
    - Removed origin selection in cad from Creadat, it is no longuer needed
    - Corrected problem when loading dats with sincs.
    - Corrected alignment of dats in projects maintenance, when using real size dats.
    - Corrected projects maintenance, side bloc distance wasn't correctly selected.
    - Corrected loading and modifying comments from the cutting screen
    - Corrected loading the size values in the cutting screen when inverting a project
    - Corrected the wire arc width in the projects maintenance, according with the width in the material and the width in the parameters
    - Augmented the size of the search files screen to get more info on the file's path
    Don't forget to visit our forum at http://foro.cenece.com, although it is mainly in spanish you're all welcome!
    Best regards,
    Javier López y Dani Sáez / Dani Sáez y Javier López
    http://www.cenece.com - CeNeCe official site
    http://foro.cenece.com - CeNeCe official Forum
    pedidospro@cenece.com - Orders and license management
    pro@cenece.com - Technical Support
    Apr 2004
    Chandler, Arizona
    I'm having trouble with trying to download the new version. I fill out all the required information but when I click on submit it generates an error. Am I doing anything wrong?
    Todd
    Jul 2005
    spain
    Hi Todd,
    you can only download the latest version if you already have bought a previuos one. You can only donwload the demo free of charge.
    what error are you getting?
    what's your browser?
    try using microsoft explorer.
    regards,
    Dani
    Apr 2004
    Chandler, Arizona
    This is the error message that I'm getting.... I'm getting this when I use IE and when I try and download the demo.
    Microsoft OLE DB Provider for ODBC Drivers error '80004005'
    [Microsoft][Controlador ODBC Microsoft Access] El campo 'demousers.Pais' no puede ser una cadena de longitud cero.
    /cenecepro/prodwnld.asp, línea 421
    Todd
    Jul 2005
    spain
    Hi Todd,
    this error has been reported by other users, it refers to not filling correctly the country field.
    you can try filling the fields manually.
    If you still have problems please PM me, and we'll solve it.
    Dani
    S.N.A.F.U. miljnor's Avatar
    Jan 2005
    Can you program cut tapered wing profiles complex airfoils?
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
  7. #7
    Jul 2005
    spain
    hi miljnor, yes of course, any wing profile, any kind of wing, as well as any shape and text.
    Dani
  8. #8
    Jan 2005
    what kind of hardware dose it need to run?
    Will a hobby cnc board with a normal break out board work?
    thanks
    Michael T.
  9. #9
    Jul 2005
    spain
    Hi Michael,
    cenece pro is designed to work with the C4 or C5 board from http://www.cenece.com, because it has the ability to use it's automatic heat control. But you can use the setup screen to configure almost any other board.
    I recomend you to read this post on rcgroups:
    http://www.rcgroups.com/forums/showt...91#post4934729
    it deals with standar boards and compares diferent softwares, a must read!
    Best regards,
    Dani
  10. #10
    Jul 2008
    The link does not really touch on the actual C4 board other than the author receiving it. And the C5 was not mentioned. Good write up on the CeNeCe software.
    Wish I could get the CeNeCe gang to answer an E-mail. Seems like the order request part of your site is not working. At least from the US.
  11. #11
    Jul 2005
    spain
    Hi chj.sullivan,
    what problems are you having??
    you can also contact me at pro@cenece.com
    Although I'm in the soft "department", I could try to help you.
    regards,
    Dani
  12. #12
    Jul 2008
    Dani,
    Sent you an E-mail to the posted address. Hope you can help. Really would like to get a package from you.
  1. Electromagnet Release
    By Zumba in forum General Electronics Discussion
    Last Post: 01-06-2008, 11:59 PM
  2. Anyone used CeNeCe?
    By captahab in forum Foam Cutting Software
    Last Post: 01-28-2007, 08:43 AM
  3. New release of CeNeCe PRO 1.07
    By DaniSaez in forum CNC Wire Foam Cutter Machines
    Last Post: 11-20-2006, 05:49 PM
  4. New CeNeCe PRO 1.06!
    Last Post: 03-02-2006, 05:24 PM
  5. RAMS 2D Release
    By Ican in forum Product and Manufacturer Announcements
    Last Post: 04-07-2005, 01:38 AM
