Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines > Foam Cutting Software
Foam Cutting Software Discuss Foam cutting software here.
Old 06-17-2007, 02:08 PM
vulcom1 is on a distinguished road
Foamworks ver.3
I am very green with CNC but for my first project I buit a foam cutter using the HCNC pro 4 axis board using Foamworks. I realize I probably should have purchased the Cadworks program with it but as a learner I did not realize how much use it was going to be. Trying to convert DXF files to a DAT file for me is also giving me headaches.
The reason for this post is I have been using notepad to do little designs and have a problem with directions. When I start a cut it reverses towards me the distance of the part that I want to cut. Then it starts foward and does the cut properly. I do not know where I am going wrong but would somebody be able to tell me how to change the direction for the initial start of the cut. The first few lines of info are
0.000000 0.000000
0.980000 0.060000
0.950000 0.100000
0.900000 0.160000
Any help is appreciatted,
John
Foamworks gar General CAM Discussion 1 11-29-2007 03:15 AM
Foamworks 2.1 and DXF2DAT 3.0 mailing lists djmrozin Product Announcements & Manufacturer News 0 02-22-2004 12:51 PM
FoamWorks 2.1 and DXF2DAT 3.0 software djmrozin Product Announcements & Manufacturer News 0 02-15-2004 10:35 PM
