| Foam Cutting Software Discuss Foam cutting software here. |
| Mark, For running that size you will probably need a full frame to support what ever you mount for motion. Mine is small for cutting wings and other items. Do a search for foamcutting and you will learn quite a bit. I did not bookmark some sites but they where cutting large blocks and one was for making sports car bodies and then glassing. I believe it was in the land of OZ. Good luck, John |
| Man, I would hate to have the bill for a 16' ballscrew! We have a dept. at work, that cuts those things, I've never seen them ship one out that long. You would have some serious whip! . Last edited by Switcher; 06-13-2007 at 04:47 PM. |
| You'd be fine with belt. Check out Hotwire Direct machines. I have done several with belt. No whip, low forces involved, low speeds. I used direct drive pulley, with 1/16 microstepping. My pulley was about .5" OD. Oh, and cheaper, easier, lower maintenance than leadscrews. From directs website specs: http://www.hotwiredirect.com/product...-machine-8700/ Cutting Capacity 106″ x 51″ x 105″ (269cm x 130cm x 266cm). Wire is 105″ long. Other sizes available. Resolution 0.001″ (0.025mm) Accuracy ±.002″/foot (0.0167mm/m) Drive Motors Five 160 ounce/inch (1.8kg/cm) AC servos, 4000 counts per revolution encoders Drive System X & Y axis timing belt drives, precision sealed bearings ride on hardened ground rods Max. Cutting Speed 55″ (140cm) per minute Max. Rapid Speed 1500″ (3,810cm) per minute Cutting Wire Up to 6 - .014 (.355mm) wires Power Required 220v single phase 50-60hz, 20 Amp Warranty 1 year on all electrical components, 3 years on all mechanical components Tech Support Unlimited support at no charg |
| Belt and pinions, a good place to buy! | chinamill5 | Europe Club House | 2 | 08-08-2008 10:42 AM |
| Racks & Pinions with gear box | eloid | Linear and Rotary Motion | 11 | 03-06-2007 02:33 PM |
| Where I can buy pinions and a 120" rack online? | kanankeban | DIY-CNC Router Table Machines | 26 | 06-26-2004 03:59 PM |
