YOUR STEPS PER REVOLUTION MUST BE CORRECT ACCORDING TO YOUR STEPPER MOTORS IE: DEGREES PER STEP AND YOUR MM PER REVOLUTION MUST BE CORRECT FOR YOUR SCREW THREAD ON YOUR X/Y AXIS THREADED BARS.
Hi
Today I finished building my CNC hotwire foam cutter. I am using MM2001 & GFMC. When I move the motor "manualy" (in the menu bar) GMFC >> Zero Axis... it works fine but when i try to cut the motors stand still.
I also tried to work with Jedicut and move the motors via the hidden right menu, i got the same results the motors doesn't move when i try to CUT.
PLZ help
Regards
Maayan
