Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines > Foam Cutting Software
Foam Cutting Software Discuss Foam cutting software here.
Old 04-15-2003, 06:42 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
What software
do you use for CNC foam cutters?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 04-27-2003, 05:00 PM
Fran is on a distinguished road
I use software by Gilles Muller at
http://gm.cnc.free.fr/index_en.html.
But here are some other links
www.cenece.com Spanish s/w for cutting wings active forum
http://www.het-holland.nl/
http://www.step-four.at/e_index.html
Cheers
Fran
Old 04-06-2004, 11:42 PM
RCjunkie's Avatar
Gold Member
RCjunkie is on a distinguished road
I use a Foam Linx
With Muller software.
Name:	cnc foam machine 2.jpg‎
2 wrongs don't make a right
But 2 Wrights makes a Airplane
Kevin Matney
www.Matneymodels.com
734 - 848 - 8195
"IN GOD WE 'TRUST "
Old 04-07-2004, 02:29 AM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
While this topic is here.
What on earth do foam cutters make?
Is it just for planes or is there other uses?
Old 04-07-2004, 04:27 PM
RCjunkie's Avatar
Gold Member
Thumbs up
Try this out
Name:	cnc foam machine 8.jpg‎
Kevin Matney
734 - 848 - 8195
"IN GOD WE 'TRUST "
Old 04-07-2004, 04:42 PM
mvaughn's Avatar
Moderator
mvaughn is on a distinguished road
Planes seem to be the main function of these machines but you can also carve out simple parts for casting metal.
Here's a link to some parts made with a foam carver.
http://buildyouridea.com/cnc/hblb/phase3/phase3.html
http://buildyouridea.com/cnc/hblb/phase7/phase7.html
http://buildyouridea.com/cnc/hblb/hblb.html
sorry for hijacking the post.
Old 11-19-2004, 10:12 AM
Redline's Avatar
Redline is on a distinguished road
I use mine for lost foam casting.I make small parts for motorcycles and old custom hot rods.
Old 08-15-2005, 09:29 PM
jerry1957 is on a distinguished road
Cool lost foam castings
do you have fotos of your cnc foam cutter, and do you have plans on this machine. thanks if you can help
Old 08-15-2005, 09:50 PM
Evodyne's Avatar
Evodyne is on a distinguished road
What are the limitations?
Originally Posted by RCjunkie
Try this out
Dang! If a guy wanted to make largish wind turbine blades (10') could this be used? Even if the blank needed both twist and taper? In other words how crazy can you get with a wing in terms of shape?
Are you using carbon fiber rods/strips in the grooves for stiffness?
And what are you skinning these with?
Thanks!
Evodyne
Old 08-16-2005, 12:44 PM
Gold Member
imserv is on a distinguished road
Some pictures of wire cut foam parts here:
http://www.astatue.com/astatue_001.htm
Fred Smith - IMService
  #11   Ban this user!
Old 08-17-2005, 08:38 PM
erase42 is on a distinguished road
twist and taper, pretty dang sure you can, ive cut stuff like that totaly by mistake on my 9 foot machine. email me each end shape, and how many degrees of twist you would like to see and ill see what my software comes up with.
erase42@aol.com
  #12   Ban this user!
Old 08-17-2005, 09:29 PM
Evodyne's Avatar
Well, what I meant to ask, and didn't do a good job of, is this: can a wing shape be cut with a non-linear taper? In other words, curved leading and/or trailing edges. The attached pic is typical of an efficient wind turbine blade.
Lance
Engraving Software The Wizard General CAM Discussion 31 03-29-2005 06:38 AM
Software sales or "license transfers" metlmunchr BobCad-Cam 3 07-05-2004 05:47 PM
***One stop CNC software guide*** ynneb DIY-CNC Router Table Machines 4 05-27-2004 05:31 PM
What software are you using? BeerFizz DIY-CNC Router Table Machines 4 12-06-2003 04:15 PM
