Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 39
Thread: ExcelCut 4 Axis Wing Cutter with Source Code
  1. #13
    Jan 2006
    malaysia
    hi highseas,
    thanks for your info about the "excelmill" broken link.
    are u flying in jb ?
    about openoffice, i've not yet play around with it. the reason i use excel 2003 to create my software is because my wife is a teacher. as a teacher she get school computer and has excel 2003 installed. so when she's not using during the night i'll take incharge.
    regarding my foam cutter machine, it's rather ugly actually. i'll consider to post some picture on my website.
    rgds,
    arman
  2. #14
    May 2007
    india
    hi arman
    I'm having some problems with the software -- like it works some time and it doesn't other times I'm running it on excel-2007 and i think I'm having an I/O problem -- like the software is not taking the port address or something like that !
    what should i do please advice
    thanks for your time
    sahil
  3. #15
    Jan 2006
    malaysia
    hi sahil,
    i don't have excel 2007 to test. may be your pc speed is too fast. try increase speed delay from 10000 to 20000. pls let me know if this help.
  4. #16
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    arman - Greetings.
    Porting the ExcelCut to Open Office would be real nice! Aa great combo - 2 freebie programs!
    Is there a way to test/check a file without having the controllers attached to the pc? I'd like to do that to make sure all is well before taking the file out to the "shop." Maybe some trick to fool the software into not looking for the controller?
    Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  • #17
    May 2007
    india
    hello arman
    i think i have not made my question clear! what i meant was--- i was having a start up problem i.e once i open the program ( for the 1st time ) i input the parallel port address and un-check the home limit option the save the file and then give power to the machine wala it works -----as far as delay speed is concerned i have gone as low as 2000 without any glitching problems .
    now for the problem , at the time of closing the program i get an saving option ( if i save the current setting are not ) once the program is closed and opened back it won't work ! but all of sudden after lots of opening and closing is works !
    I'm new to all this stuff ! and i have been running this program on IBM laptop P4 , OS-XP service pack 2 and office 2007 !
    thanks again for the help and i think its an wounder full program,i just have to work out my bugs
    sahil
  • #18
    Jan 2006
    malaysia
    hi sahil,
    try save as 2003 version. i'll test it with 2007 next week. (Holiday season in Malaysia)
    hi high seas,
    you can do that by
    1. on 'limit switch' section UNCHECKED the Enable Home & limit Switch
    2. on 'Shape Cut' section put 'Pause on Cut' = 1
    rgds,
    arman
  • #19
    May 2007
    india
    hi sahil,
    okay i will do that n have a happy holiday season
    bye
    sahil
  • #20
    May 2004
    I lost my copy of Excelcut 4.2 due to pc failure. I don't have a backup, web site is MIA, and I can't get a hold of Arman. Can some one seed me a copy to b.bixel@juno.com. I have a password to unlock the source so I good there.
    Regards,
    Bart
  • #21
    May 2004
    I finally got a hold of arman, so I'm good to go.
    Bart
    Regards,
    Bart
  • #22
    Nov 2010
    Brazil
    excelcut still available?
    Cheers arman, hi everybody!
    just came across the excelcut project - very interesting.
    I tried to locate it on the www to have a closer look but
    it seems like the links don't work (netmyne...).
    Is there any other chance to get a closer look to the
    package?
    Thanks and best regards
    Dolphi
  • #23
    Apr 2011
    Is there an alternative download site for this software. The original site seems to be down.
    Or does someone have a copy of the latest (4.2 version ?) they could send me? The software is free for personal use.
    Thanks!
  • #24
    Mar 2011
    Israel
    I am also interested
    Did you ever found how to get a hold of a copy?
    Please post here so everyone can download.
    Thanks,
    Rony
  • Page 2 of 4 FirstFirst 1234 LastLast
