Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines > Foam Cutting Software
Foam Cutting Software Discuss Foam cutting software here.
Old 09-28-2006, 12:45 AM
arman is on a distinguished road
New released - ExcelCutR3 (Experiment)
Hi all,
You are welcome to download "ExcelCutR3" (~500kb).
This new released support 'Home switch' & 'Limit Switch'.
More info at http://www.excelcut.netmyne.com .
Cheers,
arman
Old 01-17-2007, 01:27 PM
bobb is on a distinguished road
Arman,
Look at the program and it looks like the X and the Y need to move the same travel per mm
I have different screws, 18t X and 20 T Y so guess I can't run the software.
thanks
Bobb
Old 01-17-2007, 08:36 PM
hi bobb,
the software still perform the cut but will give u unexpected results.
for me its not a good idea to have diff size screw on x & y axis. but if you preffer that way then the source code is available. only minor changes.
regards,
arman
Old 01-18-2007, 12:09 AM
Arman,
thanks you for quick reply.
I am not programer so will have to pass.
foamworks is also the same.
gmfc, will let you have different X an Y, this is what I use now but was looking at all the programs to check them out.
Keep up the good work.
Regards,
bob
Old 02-14-2007, 06:39 PM
venomx999's Avatar
venomx999 is on a distinguished road
its still having alot of bugs...... :P
but its a nice program once its done.
Live life like you never see another day
Old 02-14-2007, 09:06 PM
hi venomx999,
thanks for your response.
since the program is an experimental or "just working example" bugs are expected. As for me the program served me well for cutting zagi shape wings (my favorite flying model). I'm more than happy if you could list out some of the bugs (if not all) that you encounter. suggestions are also welcome.
rgds,
arman
