Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines > Foam Cutting Software
Foam Cutting Software Discuss Foam cutting software here.
  #49   Ban this user!
Old 06-08-2007, 07:42 AM
GAWnCA's Avatar
GAWnCA is on a distinguished road
Hi Switcher,
I guess I'll just have to try it out and see what it can do. I do cut other things other than wings as I'm sure just about everyone who has a hotwire machine does. FOr some reason I can't get Foamworks to cut at the scale I enter into the settings area.
Thanks,
Greg
Originally Posted by Switcher View Post
Looks like anything in X & Y.
Old 06-08-2007, 08:48 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Originally Posted by GAWnCA View Post
Thanks Jim, That did work. I guess I'll just have to test each one against each other. Will F-Cut do other things besides wings?
Greg
Haven't tried yet! But, there is an Excell 2003 (MS Office 2003) based Vbasic that does - {Not to detract from moreil's software} The chap that did the work is a member here too. Link to his site: http://www.excelcut.netmyne.com
Soon I'll be building a small foam cutting rig - just need to settle on drivers and motors.
Sorry didn't mean to move us off thread
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  #51   Ban this user!
Old 06-08-2007, 02:19 PM
GAWnCA's Avatar
Red face
Link to ExcelMill doesn't work. I'm trying everything.
Jim
  #52   Ban this user!
Old 11-27-2007, 04:53 PM
GEFR is on a distinguished road
Smile coy new member!
Jim
I am an avid bizarre RC aeromodeller and have just completed the mechanics of an NC Foamcutter using four steppers, lead screws and Precission ground bar. I am very pleased with the way it looks and feels. I have past experience of using Autocad to generate DXF's then Cadworks into DAT files and finally Foamworks into cut files and to drive the cutter which particular machine is unfortunately is no longer available to me. I completely understand the concept of single curve and conic limitations of hot wire cutting. I am currently on the electronics using Arrons circuit off the net but In spite of having successfully laid out a red and blue for a 64K expansion board in an earlier life have had to seek assistance from a electronics aware mate as I just can't get it going. I like the apparent simplicity of the Arron circuit but wonder if anyone has got one going or knows aof another available for free download. By the way am I also off thread?
Cheers
GEFR
  #53   Ban this user!
Old 08-27-2009, 10:02 AM
v1rot8 is on a distinguished road
Driver for Gecko G540 Parallel Port Pinout
Originally Posted by moreil View Post
Released 1.0.13. Only minor changes.
I've added pinouts for the Xylotex and HobbyCNC boards. Are there other boards that people have data for?
11-Oct-2006: Back from holidays!
1. Stopped debugging messagebox appearing when changing board pinout.
2. Made changing boards work correctly.
3. Added data for Xylotex and HobbyCNC boards. Anyone got any other pinouts for me to add?
Moreil,
I'm not sure if FCut is still actively being developed or not, but I was wondering if a pinout was available for the Gecko G540. Mainly the motor controls which are through the parallel port as listed below:
Motor 1: Step Pin-2, Direction Pin-3
Motor 2: Step Pin-4, Direction Pin-5
Motor 3: Step Pin-6, Direction Pin-7
Motor 4: Step Pin-8, Direction Pin-9
The manual can be found here http://www.geckodrive.com/upload/G54...UAL%20REV1.pdf
Thanks,
Bryon
