VERY nice work!
I thought I would mention this software should work well for a wire EDM machine as well. Perhaps adding in options/functions for an EDM would be a good idea.
I have never run a wire EDM, but basic differences I see:
- Wire is usually vertical with coolant running down the wire.
- Wire is moving to keep from wearing it out.
As is it probably would work fine. Wire speed, Wire feed, and power are probably constant or have similar issues as cutting foam. Changing some dialog labels may be nice for the different machine orientation and material cut.
I haven't tried the software yet, so please forgive me is any of this is addressed.
Some other suggestions:
- I noticed a VERY early comment about syncing the 2 end profiles strictly by length. If nothing further has been done, might I suggest automatic sync points at any corners, and a button to turn on/off the display of where they are. You could also then add manually inserting points, and adjusting the automatically inserted ones.
- An idea for an automatic check that is only partly thought thru...
An automatic check to see if the wire crosses any point on either of the end geometry. This assumes the end geometry do not cross each other, or the comparison view arranges them that way. Not easy to explain, and probably harder to code... Think of a simple example of a straight , tapered airfoil. If the wire is not in sync at the trailing edge (one end on the top, and one on the bottom of the airfoil), it cuts into the middle of the trailing edge.
