Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines > Foam Cutting Software
Foam Cutting Software Discuss Foam cutting software here.
Old 10-01-2003, 11:23 AM
Alonson is on a distinguished road
Hot-Wire Cutter Software
I need Hot-Wire Cutter Software. Where can I buy ?
Old 10-01-2003, 04:04 PM
cbcnc is on a distinguished road
Hi Alonson,
Try here. Maybe it is what you want.
MM2001
Chris
Old 02-15-2004, 10:28 PM
djmrozin is on a distinguished road
Check out FoamWorks 2.1 The demo can be downloaded from www.foamwork.net
Dave Mrozinski
www.foamwork.net
Old 02-15-2004, 11:49 PM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Will a cnc controller work with foam cutting software?
Hager
Old 02-16-2004, 05:32 AM
Depends on the controller. Foamworks communicates using the parallel port and it provides step and direction pulses to the control board. If they communicate this way, there is good chance it will run.
Dave Mrozinski
Old 08-07-2005, 05:31 AM
Bilbobaker is on a distinguished road
I use Guilles Mullers software and like it very well.
It's called GMFC.
http://gm.cnc.free.fr/en/index.html
Bill
Old 12-03-2005, 04:07 PM
Moderator
JerryFlyGuy is on a distinguished road
Curious about the MM2001 Board. I've actually had one for several years and just never put it together. One issue I have is .. I don't speak french and of course all the info published for the board is in french. Does anyone know a link that has these in English? Also, have others had good sucess with this board? I'm thinking maybe I'll build it and give it a try..
JerryFlyGuy
Old 12-19-2005, 10:24 PM
erase42 is on a distinguished road
HI Jerry,
i did build a mm2001 as my first cnc/stepper project ever and had 100% success.
There is a file i found that had all the info and schematics reworked into english. I cant remember where it was, but I still have it here if you want it. Send me an email and ill answer any questions i can for you. Erase42@aol.com
ED
Old 03-02-2006, 05:00 PM
DaniSaez is on a distinguished road
Hi Alonson,
you should try the CeNeCe PRO, you can download a demo version at:
http://www.cenece.com - CeNeCe official site
http://foro.cenece.com - CeNeCe official Forum
pedidospro@cenece.com - Orders and license management
pro@cenece.com - Technical Support
Youy can use with allmost any controler, as you can set it up in the program.
Best regards,
Dani
Old 03-02-2006, 05:16 PM
Tranced_1 is on a distinguished road
English version of the MM2001 can be found here:
MM2001 English version
  #11   Ban this user!
Old 03-03-2006, 10:29 AM
vulcom1 is on a distinguished road
You can also do a search on yahoo group for cnc foam cutting. I am in the process of finding all the parts and the pic chip for the mm2001 I first got found out it would not work. You can also read about the software and then make up your mind which one to use and also get help. After you could inform all of us which way you are going on cnczone. The more knowledge to me for learning the better as I want this as my first cnc project.
John
  #12   Ban this user!
Old 05-02-2006, 12:47 PM
Porschet70 is on a distinguished road
Hi all, I'm very new to this cnc foam cutting. I have many new chips at my shop to use in this project. (sla7078mr, sla7075mr, or sla7052m) But I don't have a schematic.. The motors I plan to use are Vexta PK245-03A-C13 2phase 1.8*/step 12 volt dc .4 amp. I have 4 motors. I also have many Microchip pic chips. No programmer but lots of chips. I need a little help, please. Maybe if someone had a schematic and needed some chips we could help each other????? E-mail me at James.Malis@AKSteel.com with any advice... Thanks
CNC Hot wire Foam Cutter Krashlnd CNC Wire Foam Cutter Machines 7 01-16-2006 08:57 PM
cnc hot wire plans wanted chris69randy CNC Wire Foam Cutter Machines 2 03-11-2005 09:03 PM
E-Stop Hard Wire and to Software? Sanghera General Electronics Discussion 20 10-30-2004 12:22 AM
Nice Foam cutter! A Peterbuilt-but not wire Bloy2004 CNC Wire Foam Cutter Machines 14 05-04-2004 11:12 PM
Good Foam Cutter CAM Software? vacpress General CAM Discussion 0 03-30-2004 06:26 PM
