Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines > Foam Cutting Software
Foam Cutting Software Discuss Foam cutting software here.
  #13   Ban this user!
Old 06-04-2007, 04:23 PM
de plume/pseudonym is on a distinguished road
I wonder whether vinyl cutting software can be used ? ANYONE KNOW ?
  #14   Ban this user!
Old 06-04-2007, 05:53 PM
vulcom1 is on a distinguished road
As a followup on what I mentioned before on searchs for software. Some of the operating systems for example GMFC, Jedicut, use a board with a timer built in. Jedicut is free and I think it is the one I will eventually go to. Foamworks does not need the timer so it will run on a regular 4 axis setup. The cost for GMFC to me is prohibitive for cutting a few wings. Foamworks is $46 US which is more reasonable.
I just completed my system and I made it using the Hobby CNC Pro 4 axis board which is a kit. I am running Foamworks on the demo version and need to get the key in 20 days. My left and right stations are made with 2 ball drawer slides spaced side by side and 2 opposite for the uprights mounted on 4ft. shelving. My steppers are 84 oz. and the leadscrews 3/8"x16 tpi run very smooth. I did not use the foamcutter board they sell as I am going to convert my mill/drill shortly and my cables plug into the rear of my PS which is 24volts 32 amps which also runs my heat for the bow. I am going to purchase the timer addition to give it more flexability for software. My system is not a direct copy of anybody's but a gathering of what I have found on the web.
I have only dry cut so far but will try some foam probably tonight to see if I have any problems. If anybody has any questions I would only be to happy to help. This is my first jump into CNC and when the steppers rotated I was a happy camper.
John
ID:	38568   Click image for larger version
Old 06-05-2007, 06:07 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
This might help - but you didn't say what you wanted to cut. A few months back, a fellow based in Malaysia "gave/listed/presented" his software here on the 'Zone. It is based on excell 2003 (Office2003) and does wings, ribs, text, images. I played with it and am encouraged to do some - but first I gotta find/get a board.
I don't have the link - would have to search for it - but you might do that as well...
Jim
Here's the link - it was the next thread down http://www.excelcut.netmyne.com
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  #16   Ban this user!
Old 01-27-2008, 04:37 PM
benergy is on a distinguished road
Im looking for a utility or basic software for converting dxf files (usually text) to gcode for foam cutting on cnc table (no taper just basic 2d code) so i can select where the entry and exit points of the inside of letter and so on. I use sheet cam but seems laborious for foamcutting toolpaths....
any ideas or advice
regards
Benergy
  #17   Ban this user!
Old 02-03-2008, 10:50 PM
salvaCNC is on a distinguished road
I think it can only be done manually. Just use a good CAD program to do it as quickly as you can. No software will edit text for you since you have to choose entry and exit points.
  #18   Ban this user!
Old 02-28-2008, 01:16 AM
esawyja's Avatar
esawyja is on a distinguished road
I use DESKCNC to convert to G code from the dxf file I saved using AutoCad. DESDCNC has a nice foam module for tapered cuts as well, see http://www.poly-cor.com/
  #19   Ban this user!
Old 04-14-2008, 12:52 PM
funflyri is on a distinguished road
have you tried going to alldatasheet.com thay have the data sheet for the driver ic that you are using.
CNC Hot wire Foam Cutter Krashlnd CNC Wire Foam Cutter Machines 7 01-16-2006 07:57 PM
cnc hot wire plans wanted chris69randy CNC Wire Foam Cutter Machines 2 03-11-2005 08:03 PM
E-Stop Hard Wire and to Software? Sanghera General Electronics Discussion 20 10-29-2004 11:22 PM
Nice Foam cutter! A Peterbuilt-but not wire Bloy2004 CNC Wire Foam Cutter Machines 14 05-04-2004 10:12 PM
Good Foam Cutter CAM Software? vacpress General CAM Discussion 0 03-30-2004 05:26 PM
