Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines > Foam Cutting Software
Foam Cutting Software Discuss Foam cutting software here.
Old 01-02-2006, 11:56 PM
debogus's Avatar
debogus is on a distinguished road
Jedi cut ?
jedi cut
Just found this software,its FREE
Anybody try it ?
Just found that huge database of airfoil dats
Guess I need to make up my mind on the driver boards.( and toss together a cutter )
probably go with xylotex again ,but really don't want to spend that much.
Dave
Old 01-03-2006, 01:24 AM
txcowdog's Avatar
Gold Member
txcowdog is on a distinguished road
That looks pretty cool. I wonder if it can cut propellors for a wind turbine without me being a genius and knowing all the math needed for proper pitch, width, and length.
Old 01-03-2006, 01:50 AM
automizer's Avatar
automizer is on a distinguished road
txcowdog the internet is a wonderfull place im sure if you google what your after something will come up.
I was hoppong for some star wars item to pop up with this one but free program can't go wrong there. I looked at there forum to see what other people were saying about it but its not in english is the program in a nother language too I wonder?
Old 01-03-2006, 05:15 AM
JavaDog's Avatar
JavaDog is on a distinguished road
If you are not aware of it already, check out Fieldlines for some great homebrew turbine info...
Looks like the program lets you choose between a few languages, including English.
Nifty looking program...I wonder if it would work for milling out the wing profile from solid wood stock?
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
Old 01-03-2006, 11:34 AM
debogus's Avatar
I used google translate in the forum ,
the programs settings seem to be in french and the measurments in mm.
But its Free ,and accepts the dat airfoil files
Which they also have airfoil dats for wind turbines here.dat list
Javadog sir,
Its a foam cutter unless perphaps you cobbled together a band saw across the towers ,or maybe ran your wire real hot (sorry)
Yes yes the net is a wonderful place . Stilllooking for a alternative to a xylotex 4 axis.
Dave
Old 01-04-2006, 12:27 AM
txcowdog's Avatar
Gold Member
Thanks JavaDog for the link. Loads of info.
