Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines > Foam Cutting Software
Foam Cutting Software Discuss Foam cutting software here.
Old 01-14-2011, 07:56 AM
ixires is on a distinguished road
Software for INDIMCO ICS P800 - Profiler
Hi, guys!
I need help to run INDIMCO ICS P800 foam cutter!
At the moment we use registered STEP-FOUR cutting software v3 that runs under DOS. This software is compatible with STEP-FOUR Motor control unit SF-C2. STEP-FOUR home page here.
Problem: we need software and configuration to run this INDIMCO machine under Windows XP Pro SP2.
I tried out GMFC, but I couldn't configure table settings, because I don't know steps per revolution, nor timer value, nor pin connections.
Tags
foam, indimco, step-four, wing
Plasma CNC Pipe Profiler bturcotte Plasma, EDM and other similar machine Project Log 3 07-21-2010 12:24 AM
Tube profiler concept cnctube Benchtop Machines 25 09-24-2009 06:45 PM
Need Help!- CNC tube profiler cnctube CNC Plasma and Waterjet Machines 1 06-25-2008 10:46 AM
CNC tube profiler software/hardware IronDesign General CNC (Mill and Lathe) Control Software (NC) 5 02-17-2007 08:38 AM
Elektor Profiler, anyone? tingox Europe Club House 0 02-02-2007 11:22 AM
