Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines > Foam Cutting Software
Foam Cutting Software Discuss Foam cutting software here.
Old 07-09-2005, 08:55 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Any using Foamwork software?
I'm looking into getting some foam cutting software anyone using this - http://www.foamwork.net/
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 03-16-2006, 01:44 PM
GAWnCA's Avatar
GAWnCA is on a distinguished road
FoamWorks/CADWorks
I bought both and from what I've seen so far they are really good products and the support is there when you need it (within a reasonable time frame). Get the 30 day demo and try them out. The software is not restricted except for time. Dave is great.
Old 11-23-2006, 05:19 PM
AK47 is on a distinguished road
I have tested demo version and it works ok. Only problem is that FW only give you 1000 step/sec. That can limit cutting too slow if using low pitch screw.
Old 02-14-2007, 06:15 PM
venomx999's Avatar
venomx999 is on a distinguished road
how do you convert a file ? ... my 2D drawings keep being generated as ziggag puzzle lol
Live life like you never see another day
Old 03-25-2007, 12:49 AM
sparkyone is on a distinguished road
If you have foamworks as I have you should purchase the cadworks to go with it. It converts autocad files as well as being able to draw and shift the nodes in your drawings.
Regards Steve
Old 03-25-2007, 02:47 PM
sloper sty is on a distinguished road
venomx,
I've been cutting airplanes for 2 years with Foamworks exclusively.
As mentioned go to the site and download the free trial programs.
At a point I had a video out showing going from autocad to cadwords to foamworks.
In short you need to set the order of the lines.
They are not set that is why you got zig zag.
Load dxf file into foamworks
make a new blue layer
trace the dxf file counter clockwise starting from the right
working your way down covering any horizontal positions.
and exit on either side
Theres a few hurdles:
Sometimes in foamworks you can't get the dat file to go down to 0
A few methods resolve this fairly quickly
Knowing which way to trace something so that gravity doesnt have a bad effect on cut accuracy (from parts settling that get cut again)
Shapes can be setup to autotrace in foamworks which takes the tracing process out of it! (it requires that no lines over lap though)
Videos will be posted showing the whole foam cutting process.
I'm working on a second cutter now and need help on wire order for the motors which will be posted too.
Just ask any questions you have and the video will make sure to cover it.
Old 03-28-2007, 01:18 AM
GAWnCA's Avatar
Hey Sloper, I can hardly wait to see what you produce in a video.
Originally Posted by sloper sty View Post
venomx,
Old 04-21-2007, 10:25 PM
Wire order help
I posted this up in the motor thread if anyone can help please do!
http://www.cnczone.com/forums/showth...608#post288608
Thanks!
Old 12-27-2007, 06:33 AM
living-word is on a distinguished road
Paul,
I too am looking for wirecutter software. Jedicut and foamwork seem to be the top available for hobbiests, but they only control 4 axis. See www.megaplot.com to see video of what a 5th axis lathe/rotary table can do to take foam cutting over the top. I'm going to ask if their software is compatible with controllers other than their proprietary controllers, or if they will sell the software & controller at a reasonable price.
Old 12-27-2007, 10:16 PM
Hello Paul
I was using foamworks which is good and it does not have the 5th axis.
It would be nice to have this facillity, to cut eliptical wings for aircraft.
I was using the stepper driver UCn5804b, one channel stopped working.
I was told that this chip is no longer available. I rebuilt the controller using
the GMFC french site. This controller works well and is cheap to build but the software
is more expensive than foam works.
All the software that I have seen on the net, have not the 5th axis.
Another way of machining foam is with sandpaper glued to a mandrill cutter.
Using a 5axis router with B and C axis you can then cut 3D.
This method is a bit messy as foam dust goes all over the place.
In the automotive industry they use this method for lost foam castings.
  #11   Ban this user!
Old 12-28-2007, 01:24 PM
vulcom1 is on a distinguished road
I use Foamworks also. One was to much money for what I wanted to do and the other one I never did get working right but it is still loaded. Maybe play with it after to find the problem.
Foamworks is running with my Hobbycnc 4 axiz pro system and although it is not as fast cutting as some want it does the job for me. My screws are 3/8" x 16 tpi and was originally going to use 1/4x20 but a friend said that would be real slow. If I need to speed it up I would have to change the ready rod to less tpi.
The 2 programs available from the foamworks site work hand in hand which I have but there are also other small programs available for free that can also convert files for you. I am into wing cutting and playing around with different shapes to make fuselages for small electrics. Later it will be large scale when I get some time.
Try the demo and play around with the settings to see if it is what you want. I crossed up initially as I was playing with the program before I built the cutter. When I finished my cutter the time had expired on the demo which created a problem and I could not do any trial cuts.
John
  #12   Ban this user!
Old 01-21-2008, 11:01 PM
freejac is on a distinguished road
For those using the 5804B chips, they are still available from source 1 for $18.25 each, the drawback is you must by a tube of them (25 peices) to get them. If theres a group that would like to go in to purchase them, let me know Ill send you a link to their ordering page.
cant believe i purchased them 2 years ago for 6 dollars a pop....
