| FlashCut CNC Discuss FlashCut CNC software here! |
Hello I have been trying to load a sample gcode file from a demo version of CNCWrapper V2. into Flashcut 2. The tool path does not display properly.Instead of text being wrapped around the X axis it displays as just lines in the X-Z plane. I have check marked the box for A axis in the machine tool configuration menu I also have Rotary selected for 4th axis type. The code was created to wrap around the X axis . It seems to me Flashcut does not recognize this and I cant find a option in the Config menu to choose axis of rotation. I would appreciate any help someone has to offer. Dave E |
| what version of flashcut are you using? i have never done any fourth axis but if you post your g-code file i will try it on mine to see. have you called flashcut they are usually very helpful. they spent a couple of hours on the phone with me back and fourth helping me figure out my usb to serial converter wasn't putting out the correct baudrate. but i will be happy to help Rob |
| Hello Rob Thanks for responding. This is a sample file from a conversion program called CNCWRAPPER. It opens up and displays correct in a demo version of Mach3. When I open it in Flascut (version 2.0.3 ) it displays as linier lines in the X-Z plane instead of text wrapped on a radius. I do get some varied results if I play with spacing in the code so I am thinking it might be a posting problem,or I am missing a setting. I say a setting problem because I can create the same results in Mach3 that I get in Flashcut by not checking the X axis in the "AXIS OF ROTATION" tab. I can not find any option like this in Flaschcut other then in the "MACHINE TOOL" set up screen you can choose A under "USE AXIS" and rotary under "4TH AXIS TYPE". I never thought to call Flashcut. I have owned there system for so long now that I figured I am not eligable for any free support anymore. Anyway thanks again for the offer to help, anything you can do will be apreciated. Dave N90G00X-0.1250A30.016Z1.2362 N100G01Z0.9750F19.7 N110G01X0.1249A29.343F39.4 N120X-0.0625A28.218 N130X0.1249A27.093 N140X-0.1250A26.416 N150G00Z1.2362 N160G00A25.426 N170G01Z0.9750F19.7 N180G01X0.1249A24.753F39.4 N190X-0.0625A23.628 N200X0.1249A22.502 N210X-0.1250A21.827 N220G00Z1.2362 N230G00A20.837 N240G01Z0.9750F19.7 N250G01X0.1249A20.164F39.4 N260X-0.0625A19.039 N270X0.1249A17.914 N280X-0.1250A17.237 N290G00Z1.2362 N300G00X0.1208A16.174 N310G01Z0.9750F19.7 N320G01X0.1162F39.4 N330A16.089 N340X0.1208 N350A16.174 N360X0.1249A16.247 N370X0.1125 N380A16.022 N390X0.1249 N400A16.247 N410G00Z1.2362 N420G00X0.0624A12.782 N430G01Z0.9750F19.7 N440G01X0.0700A12.788F39.4 N450X0.0771A12.807 N460X0.0836A12.838 N470X0.0897A12.879 N480X0.0953A12.930 N490X0.1004A12.989 N500X0.1051A13.058 N510X0.1092A13.133 N520X0.1160A13.304 N530X0.1209A13.493 N540X0.1238A13.697 N550X0.1248A13.907 N560X0.1238A14.118 N570X0.1209A14.321 N580X0.1160A14.510 N590X0.1129A14.598 N600X0.1092A14.681 N610X0.1051A14.757 N620X0.1004A14.825 N630X0.0953A14.885 N640X0.0897A14.935 N650X0.0836A14.976 N660X0.0771A15.007 N670X0.0700A15.027 N680X0.0624A15.032 N690X-0.0626 N700X-0.0701A15.027 N710X-0.0772A15.007 N720X-0.0837A14.976 N730X-0.0898A14.935 N740X-0.0954A14.885 N750X-0.1005A14.825 N760X-0.1052A14.757 N770X-0.1093A14.681 N780X-0.1161A14.510 N790X-0.1210A14.321 N800X-0.1239A14.118 N810X-0.1249A13.907 N820X-0.1239A13.697 N830X-0.1210A13.493 N840X-0.1161A13.304 N850X-0.1130A13.216 N860X-0.1093A13.133 N870X-0.1052A13.058 N880X-0.1005A12.989 N890X-0.0954A12.930 N900X-0.0898A12.879 N910X-0.0837A12.838 N920X-0.0772A12.807 N930X-0.0701A12.788 N940X-0.0626A12.782 N950G00Z1.2362 N960G00X0.1249A11.792 N970G01Z0.9750F19.7 N980G01X-0.1250F39.4 N990X0.1249A9.542 N1000X-0.1250 N1010G00Z1.2362 N1020G00X0.0624A6.300 N1030G01Z0.9750F19.7 N1040G01X0.0700A6.307F39.4 N1050X0.0771A6.325 N1060X0.0836A6.356 N1070X0.0897A6.397 N1080X0.0953A6.448 N1090X0.1004A6.509 N1100X0.1051A6.577 N1110X0.1092A6.653 N1120X0.1160A6.822 N1130X0.1209A7.013 N1140X0.1238A7.216 N1150X0.1248A7.427 N1160X0.1238A7.636 N1170X0.1209A7.839 N1180X0.1160A8.030 N1190X0.1129A8.118 N1200X0.1092A8.199 N1210X0.1051A8.275 N1220X0.1004A8.343 N1230X0.0953A8.404 N1240X0.0897A8.455 N1250X0.0836A8.496 N1260X0.0771A8.527 N1270X0.0700A8.545 N1280X0.0624A8.552 N1290X-0.0626 N1300X-0.0701A8.545 N1310X-0.0772A8.527 N1320X-0.0837A8.496 N1330X-0.0898A8.455 N1340X-0.0954A8.404 N1350X-0.1005A8.343 N1360X-0.1052A8.275 N1370X-0.1093A8.199 N1380X-0.1161A8.030 N1390X-0.1210A7.839 N1400X-0.1239A7.636 N1410X-0.1249A7.427 N1420X-0.1239A7.216 N1430X-0.1210A7.013 N1440X-0.1161A6.822 N1450X-0.1130A6.734 N1460X-0.1093A6.653 N1470X-0.1052A6.577 N1480X-0.1005A6.509 N1490X-0.0954A6.448 N1500X-0.0898A6.397 N1510X-0.0837A6.356 N1520X-0.0772A6.325 N1530X-0.0701A6.307 N1540X-0.0626A6.300 N1550G00Z1.2362 N1560G00X-0.1250A5.310 N1570G01Z0.9750F19.7 N1580G01X0.1249A4.637F39.4 N1590X-0.0625A3.512 N1600X0.1249A2.387 N1610X-0.1250A1.712 N1620G00Z1.2362 N1630G00X0.1249A0.722 N1640G01Z0.9750F19.7 N1650G01X-0.1250F39.4 N1660A-0.414 N1670X-0.1248A-0.524 N1680X-0.1239A-0.630 N1690X-0.1224A-0.734 N1700X-0.1203A-0.835 N1710X-0.1177A-0.932 N1720X-0.1146A-1.024 N1730X-0.1109A-1.111 N1740X-0.1067A-1.190 N1750X-0.1023A-1.265 N1760X-0.0975A-1.332 N1770X-0.0923A-1.390 N1780X-0.0868A-1.438 N1790X-0.0812A-1.478 N1800X-0.0753A-1.505 N1810X-0.0692A-1.523 N1820X-0.0631A-1.528 N1830X-0.0569A-1.523 N1840X-0.0508A-1.507 N1850X-0.0448A-1.480 N1860X-0.0391A-1.440 N1870X-0.0336A-1.393 N1880X-0.0284A-1.334 N1890X-0.0235A-1.265 N1900X-0.0190A-1.188 N1910X-0.0147A-1.109 N1920X-0.0109A-1.022 N1930X-0.0077A-0.929 N1940X-0.0050A-0.830 N1950X-0.0029A-0.727 N1960X-0.0013A-0.621 N1970X-0.0004A-0.513 N1980X-0.0001A-0.401 N1990A0.716 N2000G00Z1.2362 N2010G00X0.0000A-0.549 N2020G01Z0.9750F19.7 N2030G01X0.1249A-1.528F39.4 N2040G00Z1.2362 N2050G00A-2.518 N2060G01Z0.9750F19.7 N2070G01X-0.1250A-3.643F39.4 N2080X0.1249A-4.768 N2090G00Z1.2362 N2100G00X0.0615A-2.822 N2110G01Z0.9750F19.7 N2120G01A-4.468F39.4 N2130G00Z1.2362 N2140G00X0.1249A-5.758 N2150G01Z0.9750F19.7 N2160G01X-0.1250F39.4 N2170A-6.894 N2180X-0.1248A-7.004 N2190X-0.1239A-7.110 N2200X-0.1224A-7.215 N2210X-0.1203A-7.315 N2220X-0.1177A-7.413 N2230X-0.1146A-7.504 N2240X-0.1109A-7.591 N2250X-0.1067A-7.670 N2260X-0.1023A-7.746 N2270X-0.0975A-7.812 N2280X-0.0923A-7.870 N2290X-0.0868A-7.918 N2300X-0.0812A-7.958 N2310X-0.0753A-7.985 N2320X-0.0692A-8.003 N2330X-0.0631A-8.008 N2340X-0.0569A-8.003 N2350X-0.0508A-7.987 N2360X-0.0448A-7.960 N2370X-0.0391A-7.922 N2380X-0.0336A-7.873 N2390X-0.0284A-7.814 N2400X-0.0235A-7.746 N2410X-0.0190A-7.668 N2420X-0.0147A-7.589 N2430X-0.0109A-7.503 N2440X-0.0077A-7.409 N2450X-0.0050A-7.310 N2460X-0.0029A-7.207 N2470X-0.0013A-7.101 N2480X-0.0004A-6.993 N2490X-0.0001A-6.882 N2500A-5.764 N2510G00Z1.2362 N2520G00X0.1249A-8.998 N2530G01Z0.9750F19.7 N2540G01X-0.1250F39.4 N2550A-10.134 N2560X-0.1248A-10.244 N2570X-0.1239A-10.350 N2580X-0.1224A-10.455 N2590X-0.1203A-10.556 N2600X-0.1177A-10.653 N2610X-0.1146A-10.745 N2620X-0.1109A-10.831 N2630X-0.1067A-10.910 N2640X-0.1023A-10.986 N2650X-0.0975A-11.052 N2660X-0.0923A-11.110 N2670X-0.0868A-11.159 N2680X-0.0812A-11.198 N2690X-0.0753A-11.225 N2700X-0.0692A-11.243 N2710X-0.0631A-11.249 N2720X-0.0569A-11.243 N2730X-0.0508A-11.227 N2740X-0.0448A-11.200 N2750X-0.0391A-11.162 N2760X-0.0336A-11.114 N2770X-0.0284A-11.054 N2780X-0.0235A-10.986 N2790X-0.0190A-10.908 N2800X-0.0147A-10.829 N2810X-0.0109A-10.743 N2820X-0.0077A-10.649 N2830X-0.0050A-10.550 N2840X-0.0029A-10.448 N2850X-0.0013A-10.341 N2860X-0.0004A-10.233 N2870X-0.0001A-10.122 N2880A-9.004 N2890G00Z1.2362 N2900G00X0.1249A-14.489 N2910G01Z0.9750F19.7 N2920G01A-12.239F39.4 N2930X-0.1250 N2940A-14.489 N2950G00Z1.2362 N2960G00X-0.0125A-12.240 N2970G01Z0.9750F19.7 N2980G01A-13.733F39.4 N2990G00Z1.2362 N3000G00X0.1249A-15.479 N3010G01Z0.9750F19.7 N3020G01X-0.1250F39.4 N3030A-16.615 N3040X-0.1248A-16.724 N3050X-0.1239A-16.831 N3060X-0.1224A-16.935 N3070X-0.1203A-17.036 N3080X-0.1177A-17.133 N3090X-0.1146A-17.225 N3100X-0.1109A-17.311 N3110X-0.1067A-17.390 N3120X-0.1023A-17.466 N3130X-0.0975A-17.533 N3140X-0.0923A-17.590 N3150X-0.0868A-17.639 N3160X-0.0812A-17.678 N3170X-0.0753A-17.705 N3180X-0.0692A-17.723 N3190X-0.0631A-17.729 N3200X-0.0569A-17.723 N3210X-0.0508A-17.707 N3220X-0.0448A-17.680 N3230X-0.0391A-17.642 N3240X-0.0336A-17.594 N3250X-0.0284A-17.534 N3260X-0.0235A-17.466 N3270X-0.0190A-17.389 N3280X-0.0147A-17.309 N3290X-0.0109A-17.223 N3300X-0.0077A-17.129 N3310X-0.0050A-17.030 N3320X-0.0029A-16.928 N3330X-0.0013A-16.822 N3340X-0.0004A-16.714 N3350X-0.0001A-16.602 N3360A-15.484 N3370G00Z1.2362 N3380G00X0.0000A-16.750 N3390G01Z0.9750F19.7 N3400G01X0.1249A-17.729F39.4 N3410G00Z1.2362 N3420G00X0.1208A-18.794 N3430G01Z0.9750F19.7 N3440G01X0.1162F39.4 N3450A-18.877 N3460X0.1208 N3470A-18.794 N3480X0.1249A-18.719 N3490X0.1125 N3500A-18.944 N3510X0.1249 N3520A-18.719 N3530G00Z1.2362 N3540G00X0.0624A-22.186 N3550G01Z0.9750F19.7 N3560G01X0.0700A-22.178F39.4 N3570X0.0771A-22.160 N3580X0.0836A-22.130 N3590X0.0897A-22.088 N3600X0.0953A-22.038 N3610X0.1004A-21.977 N3620X0.1051A-21.908 N3630X0.1092A-21.833 N3640X0.1160A-21.664 N3650X0.1209A-21.473 N3660X0.1238A-21.269 N3670X0.1248A-21.061 N3680X0.1238A-20.850 N3690X0.1209A-20.647 N3700X0.1160A-20.456 N3710X0.1129A-20.368 N3720X0.1092A-20.287 N3730X0.1051A-20.211 N3740X0.1004A-20.143 N3750X0.0953A-20.081 N3760X0.0897A-20.031 N3770X0.0836A-19.990 N3780X0.0771A-19.959 N3790X0.0700A-19.941 N3800X0.0624A-19.934 N3810X-0.0626 N3820X-0.0701A-19.941 N3830X-0.0772A-19.959 N3840X-0.0837A-19.990 N3850X-0.0898A-20.031 N3860X-0.0954A-20.081 N3870X-0.1005A-20.143 N3880X-0.1052A-20.211 N3890X-0.1093A-20.287 N3900X-0.1161A-20.456 N3910X-0.1210A-20.647 N3920X-0.1239A-20.850 N3930X-0.1249A-21.061 N3940X-0.1239A-21.269 N3950X-0.1210A-21.473 N3960X-0.1161A-21.664 N3970X-0.1130A-21.752 N3980X-0.1093A-21.833 N3990X-0.1052A-21.908 N4000X-0.1005A-21.977 N4010X-0.0954A-22.038 N4020X-0.0898A-22.088 N4030X-0.0837A-22.130 N4040X-0.0772A-22.160 N4050X-0.0701A-22.178 N4060X-0.0626A-22.186 N4070G00Z1.2362 N4080G00A-23.176 N4090G01Z0.9750F19.7 N4100G01X-0.0701A-23.181F39.4 N4110X-0.0772A-23.201 N4120X-0.0837A-23.232 N4130X-0.0898A-23.271 N4140X-0.0954A-23.323 N4150X-0.1005A-23.383 N4160X-0.1052A-23.451 N4170X-0.1093A-23.527 N4180X-0.1161A-23.698 N4190X-0.1210A-23.887 N4200X-0.1239A-24.090 N4210X-0.1249A-24.301 N4220X-0.1239A-24.510 N4230X-0.1210A-24.713 N4240X-0.1161A-24.904 N4250X-0.1130A-24.992 N4260X-0.1093A-25.073 N4270X-0.1052A-25.149 N4280X-0.1005A-25.217 N4290X-0.0954A-25.278 N4300X-0.0898A-25.329 N4310X-0.0837A-25.370 N4320X-0.0772A-25.401 N4330X-0.0701A-25.419 N4340X-0.0626A-25.426 N4350X0.0624 N4360X0.0700A-25.419 N4370X0.0771A-25.401 N4380X0.0836A-25.370 N4390X0.0897A-25.329 N4400X0.0953A-25.278 N4410X0.1004A-25.217 N4420X0.1051A-25.149 N4430X0.1092A-25.073 N4440X0.1160A-24.904 N4450X0.1209A-24.713 N4460X0.1238A-24.510 N4470X0.1248A-24.301 N4480X0.1238A-24.090 N4490X0.1209A-23.887 N4500X0.1160A-23.698 N4510X0.1129A-23.610 N4520X0.1092A-23.527 N4530X0.1051A-23.451 N4540X0.1004A-23.383 N4550X0.0953A-23.323 N4560X0.0897A-23.271 N4570X0.0836A-23.232 N4580X0.0771A-23.201 N4590X0.0700A-23.181 N4600X0.0624A-23.176 N4610X-0.0626 N4620G00Z1.2362 N4630G00X0.1250A-26.416 N4640G01Z0.9750F19.7 N4650G01X-0.1250F39.4 N4660X0.0626A-28.216 N4670X-0.1250A-30.016 N4680X0.1250 N4690G00Z1.2362 N4700G00X0.5000A-36.001 N4710G01Z0.9750F19.7 N4720G01X-0.5000F39.4 N4730X-0.5001A-35.798 N4740X-0.5005A-35.594 N4750X-0.5012A-35.387 N4760X-0.5021A-35.178 N4770X-0.5033A-34.970 N4780X-0.5048A-34.761 N4790X-0.5066A-34.548 N4800X-0.5086A-34.336 N4810X-0.5110A-34.124 N4820X-0.5137A-33.911 N4830X-0.5166A-33.697 N4840X-0.5199A-33.485 N4850X-0.5235A-33.272 N4860X-0.5275A-33.058 N4870X-0.5317A-32.847 N4880X-0.5363A-32.635 N4890X-0.5412A-32.424 N4900X-0.5464A-32.216 N4910X-0.5519A-32.009 N4920X-0.5577A-31.803 N4930X-0.5639A-31.600 N4940X-0.5703A-31.398 N4950X-0.5771A-31.199 N4960X-0.5842A-31.002 N4970X-0.5916A-30.810 N4980X-0.5993A-30.619 N4990X-0.6072A-30.432 N5000X-0.6155A-30.248 N5010X-0.6240A-30.068 N5020X-0.6328A-29.894 N5030X-0.6418A-29.721 N5040X-0.6511A-29.553 N5050X-0.6607A-29.391 N5060X-0.6704A-29.233 N5070X-0.6804A-29.080 N5080X-0.6906A-28.930 N5090X-0.7010A-28.788 N5100X-0.7116A-28.650 N5110X-0.7223A-28.516 N5120X-0.7332A-28.389 N5130X-0.7443A-28.266 N5140X-0.7555A-28.151 N5150X-0.7668A-28.039 N5160X-0.7782A-27.935 N5170X-0.7897A-27.836 N5180X-0.8013A-27.742 N5190X-0.8130A-27.654 N5200X-0.8248A-27.571 N5210X-0.8365A-27.496 N5220X-0.8484A-27.424 N5230X-0.8602A-27.359 N5240X-0.8720A-27.300 N5250X-0.8839A-27.247 N5260X-0.8957A-27.199 N5270X-0.9075A-27.156 N5280X-0.9193A-27.120 N5290X-0.9311A-27.087 N5300X-0.9427A-27.060 N5310X-0.9543A-27.039 N5320X-0.9659A-27.022 N5330X-0.9774A-27.010 N5340X-0.9887A-27.003 N5350X-1.0000A-27.001 N5360A27.001 N5370X-0.9887A27.003 N5380X-0.9774A27.010 N5390X-0.9659A27.022 N5400X-0.9543A27.039 N5410X-0.9427A27.060 N5420X-0.9311A27.087 N5430X-0.9193A27.120 N5440X-0.9075A27.156 N5450X-0.8957A27.199 N5460X-0.8839A27.247 N5470X-0.8720A27.300 N5480X-0.8602A27.359 N5490X-0.8484A27.424 N5500X-0.8365A27.496 N5510X-0.8248A27.571 N5520X-0.8130A27.654 N5530X-0.8013A27.742 N5540X-0.7897A27.836 N5550X-0.7782A27.935 N5560X-0.7668A28.039 N5570X-0.7555A28.151 N5580X-0.7443A28.266 N5590X-0.7332A28.389 N5600X-0.7223A28.516 N5610X-0.7116A28.650 N5620X-0.7010A28.788 N5630X-0.6906A28.930 N5640X-0.6804A29.080 N5650X-0.6704A29.233 N5660X-0.6607A29.391 N5670X-0.6511A29.553 N5680X-0.6418A29.721 N5690X-0.6328A29.894 N5700X-0.6240A30.068 N5710X-0.6155A30.248 N5720X-0.6072A30.432 N5730X-0.5993A30.619 N5740X-0.5916A30.810 N5750X-0.5842A31.002 N5760X-0.5771A31.199 N5770X-0.5703A31.398 N5780X-0.5639A31.600 N5790X-0.5577A31.803 N5800X-0.5519A32.009 N5810X-0.5464A32.216 N5820X-0.5412A32.424 N5830X-0.5363A32.635 N5840X-0.5317A32.847 N5850X-0.5275A33.058 N5860X-0.5235A33.272 N5870X-0.5199A33.485 N5880X-0.5166A33.697 N5890X-0.5137A33.911 N5900X-0.5110A34.124 N5910X-0.5086A34.336 N5920X-0.5066A34.548 N5930X-0.5048A34.761 N5940X-0.5033A34.970 N5950X-0.5021A35.178 N5960X-0.5012A35.387 N5970X-0.5005A35.594 N5980X-0.5001A35.798 N5990X-0.5000A36.001 N6000X0.5000 N6010X0.5001A35.798 N6020X0.5005A35.594 N6030X0.5012A35.387 N6040X0.5021A35.178 N6050X0.5033A34.970 N6060X0.5048A34.761 N6070X0.5066A34.548 N6080X0.5086A34.336 N6090X0.5110A34.124 N6100X0.5137A33.911 N6110X0.5166A33.697 N6120X0.5199A33.485 N6130X0.5235A33.272 N6140X0.5275A33.058 N6150X0.5317A32.847 N6160X0.5363A32.635 N6170X0.5412A32.424 N6180X0.5464A32.216 N6190X0.5519A32.009 N6200X0.5577A31.803 N6210X0.5639A31.600 N6220X0.5703A31.398 N6230X0.5771A31.199 N6240X0.5842A31.002 N6250X0.5916A30.810 N6260X0.5993A30.619 N6270X0.6072A30.432 N6280X0.6155A30.248 N6290X0.6240A30.068 N6300X0.6328A29.894 N6310X0.6418A29.721 N6320X0.6511A29.553 N6330X0.6607A29.391 N6340X0.6704A29.233 N6350X0.6804A29.080 N6360X0.6906A28.930 N6370X0.7010A28.788 N6380X0.7116A28.650 N6390X0.7223A28.516 N6400X0.7332A28.389 N6410X0.7443A28.266 N6420X0.7555A28.151 N6430X0.7668A28.039 N6440X0.7782A27.935 N6450X0.7897A27.836 N6460X0.8013A27.742 N6470X0.8130A27.654 N6480X0.8248A27.571 N6490X0.8365A27.496 N6500X0.8484A27.424 N6510X0.8602A27.359 N6520X0.8720A27.300 N6530X0.8839A27.247 N6540X0.8957A27.199 N6550X0.9075A27.156 N6560X0.9193A27.120 N6570X0.9311A27.087 N6580X0.9427A27.060 N6590X0.9543A27.039 N6600X0.9659A27.022 N6610X0.9774A27.010 N6620X0.9887A27.003 N6630X1.0000A27.001 N6640A-27.001 N6650X0.9887A-27.003 N6660X0.9774A-27.010 N6670X0.9659A-27.022 N6680X0.9543A-27.039 N6690X0.9427A-27.060 N6700X0.9311A-27.087 N6710X0.9193A-27.120 N6720X0.9075A-27.156 N6730X0.8957A-27.199 N6740X0.8839A-27.247 N6750X0.8720A-27.300 N6760X0.8602A-27.359 N6770X0.8484A-27.424 N6780X0.8365A-27.496 N6790X0.8248A-27.571 N6800X0.8130A-27.654 N6810X0.8013A-27.742 N6820X0.7897A-27.836 N6830X0.7782A-27.935 N6840X0.7668A-28.039 N6850X0.7555A-28.151 N6860X0.7443A-28.266 N6870X0.7332A-28.389 N6880X0.7223A-28.516 N6890X0.7116A-28.650 N6900X0.7010A-28.788 N6910X0.6906A-28.930 N6920X0.6804A-29.080 N6930X0.6704A-29.233 N6940X0.6607A-29.391 N6950X0.6511A-29.553 N6960X0.6418A-29.721 N6970X0.6328A-29.894 N6980X0.6240A-30.068 N6990X0.6155A-30.248 N7000X0.6072A-30.432 N7010X0.5993A-30.619 N7020X0.5916A-30.810 N7030X0.5842A-31.002 N7040X0.5771A-31.199 N7050X0.5703A-31.398 N7060X0.5639A-31.600 N7070X0.5577A-31.803 N7080X0.5519A-32.009 N7090X0.5464A-32.216 N7100X0.5412A-32.424 N7110X0.5363A-32.635 N7120X0.5317A-32.847 N7130X0.5275A-33.058 N7140X0.5235A-33.272 N7150X0.5199A-33.485 N7160X0.5166A-33.697 N7170X0.5137A-33.911 N7180X0.5110A-34.124 N7190X0.5086A-34.336 N7200X0.5066A-34.548 N7210X0.5048A-34.761 N7220X0.5033A-34.970 N7230X0.5021A-35.178 N7240X0.5012A-35.387 N7250X0.5005A-35.594 N7260X0.5001A-35.798 N7270X0.5000A-36.001 N7280G00Z1.2362 N7290G00Z1.2362 N7300G00X0.0000A0.000 N7310M09 N7320M30 % |
| go into the configure menu and look under viewports and set the xyza view port an it should work. i just tried it on 2.1.4 and 3 versions i dont have 2.3 but it should have the same settings. the flashcut guys always seem to find time to help. |
| Hey Rob. Thanks for taking the time to help.I apreciate it. I took your advise and emailed Flashcut. Ron Worth replyed back the same day. My old version (2.0.3) will not do what I am trying to do. I downloaded Version 3 demo and it worked fine. Looks like I need to get my wallet out and upgrade. Thanks again |
| Ron said he will give me 500.00 trade in for my old signal generator. I would like to upgrade but from the specs for the new controller my existing computer is a little lacking and I just am not in a position right now to make that much of a investment. I have been trying to get Mach3 and my Flashcut driver to play nice but so far no go. If anybody reading this has any experience doing this I would appreciate any help. |
| Hi Everyone. I have been reading these posts with great interest. I also have a flashcut four axis controller and i run version 2.04 I set it up on a benchtop milling machine. I have never used the fourth axis though I have had the machine quite a few years ago. health problems put everything on hold for a while. Now I am just starting to get back into everything and could do with some advice please. I have got to the stage of adding a stepper motor onto the back of a small woodlathe ( carbatec ) and am hoping to run it as the fourth axis on the bed of the milling machine. I work only with wood and hope to produce spiral turnings ( barley twist and fluting ) also to decorate and embellish small turnings if possible ( similar to stuff done on those horribly expensive rose engines and holtzappfell lathes of the Victorian time ) I have tried the program cnc wrapper have suffered the same sort of problems as mentioned by densman when testing the files that come with the program, the display is shown as flat rather than cylindrical and the machine doesnt seem to like the code. I was also wondering if it would be possible to make the flashcut controller like mach3 as I have read lots of posts saying how good that software is. Any help or advice that anyone can give me will be very much appreciated. Best regards. graham |
| "Make the Flashcut controller like Mach"..... Ah, not sure why you would want to do that... But frankly, version 2.04 is from early 2006 as best I can tell. So many new features and code support additions have been added since then, it would almost be a must to upgrade for anything beyond basic 2.5d or 3d work. I realize this is a Flashcut forum, but really, if people want to try Mach, it doesn't take much to make an alternative cable to connect to your driver cabinet and give it a whirl. I can tell you that you will find a few things missing that you have come to really appreciate, even though mach has "workarounds". You may never get that far though. By the time your somewhat happy with the operation from fiddling with the plethora of machs vaguely defined configuration checkboxes and dialogs, your first runs will wonder why you left the really well laid out controller Flashcut already is. Granted, 2.04 is going to be a bit antiquated though in 2012.
__________________ Chris L |
#10
__________________ Chris L Last edited by datac; 02-03-2012 at 12:00 AM. |
#11
| Hi Chris. Thanks very much for your reply. Sorry, I meant to ask if it was possible to get the flashcut four axis driver box ( not controller ) to work with mach so I could try it out. You mention that it is possible to make an alternative cable to connect to your driver cabinet and run mach3, would you mind giving me some advice or information on how to go about it please as I am new to elecronics. Thanks . Best regards. Graham |
#12
If you wanted to try Mach on your currently Flashcut driven machine, it does come down to a simple cable, breakout board or configurable pin db25 adapter. Essentially, your Flashcut signal generator has a db25 pin connector on the back. Out of this plug (among other things on newer versions), are the signals that tell the motor drivers what to do. The most basic explanation of the magic behind a system like this, is simple. There are pulses that go out of the STEP pins to tell the motors how far and how fast to turn, and there is a plus or minus signal that leaves the DIR pins to tell the motors which direction it should be turning. Each axis has a STEP, DIR and a common ground. Mach has the same scenario and even uses the same style plug. They just use different pins on that plug. For example, FC uses pin 9 for axis 1 DIR, and pin 13 for axis 1 STEP. Mach uses a different set of pins, so you have to sit down with a piece of paper and draw a map of what pins going into your driver box need what pins coming out of your parallel port directly on the PC. You do not use the Flashcut box or software at all with new cable or adapter in place. And, you could make it all run with the demo of Mach,,, it will cut 500 lines of code for free they tell me. If you do it right, you could actually swap back and forth between the two programs just by swapping cables. If you were to do this, I would hope you would come back and tell us your experiences. If you dont have a more recent version of FC, Mach might impress you with features that are newer than your FC version has. I have swapped two Mach installations to Flashcut. You can not find a more ergonomic, easy to train users, robust control to date. I couldn't imagine not using FC unless I was really down and out and could not afford it.
| the Difference of 2-Axis and 3-Axis of Vertical Mill Machine | begacon | Knee Vertical Mills | 6 | 07-30-2009 06:31 AM |
| Compare Catia and MCX2 for multi axis lathe/4 axis mill | bob1112 | General CAM Discussion | 0 | 10-10-2008 07:15 PM |
| How can I coupling a stepper motor axis directly to other axis? | meknik2001 | Stepper Motors and Drives | 4 | 05-08-2008 01:54 PM |
| One axis (z-axis?) computer controlled testing device | TsThorsell | Stepper Motors and Drives | 3 | 02-07-2008 12:38 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
