Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > FlashCut CNC
FlashCut CNC Discuss FlashCut CNC software here!
Old 05-29-2004, 11:21 AM
Swede's Avatar
Swede is on a distinguished road
Z axis touch probe
Can anyone think of a way to set Z with FC 2.0 using either a macro or built-in routine using a touch probe? For tool changes, it'd be nice to have the mill drive to a tool change location, pause, allow the tool swap, then drive down on a switch or other device and so reset the Z.
Thanks!
Old 05-31-2004, 08:28 PM
richardl is on a distinguished road
Doesn't the homing function do this with the limit switches? I don't have my limit switches installed on my FC system to I don't know how well it works in practice.
Old 05-31-2004, 08:32 PM
balsaman's Avatar
balsaman is on a distinguished road
Does flashcut support numbered tool offsets? Did you see this thread? Not exactly what you are after but can make things a little easier.
DIY Z axis 0 plate. It works perfect!
I wish it wouldn't crash.
Old 06-01-2004, 11:08 AM
Swede's Avatar
Richard, I could use a limit switch in this fashion, but my problem lies in semi-automating it so that program Z = 0 is automatically set. The limit switches normally set machine 0, not program 0. I'm having a tough time devising some sort of macro process which will do this.
Eric, I remember that thread and that is what got me started a bit in doing this process. I know that I can make an accurate fixture, it's incorporating it into a tool-change sequence that's giving me grief. The best that I can do right now is note the relative Z produced by a newly chucked tool in the collet, and manually altering the program Z=0 given the new tool's Z.
Thanks guys.
Old 06-01-2004, 01:30 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
This is were fixed tooling will do the trick.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 06-01-2004, 03:45 PM
Bubba's Avatar
Bubba is on a distinguished road
What I have done, it to have a "portable" home switch on my Z axis.
After doing a tooling change, I G00 to the point where my switch is located AND previously set to the height of the top of the work piece. I then do a G28 (I use TurboCnc with enhancements) to zero the tool. I also have T0 set to allow full travel of the quill. This allows me to T0 raise the quill to a known point so I can change tools.
This is also predicated on my having set it up so Z zero is DOWN and not up as is convention.
Works real well for me and beats the cost of fixed lenth tooling (that I will never seat exactly the same each time on my drawbar machine
Art
Old 02-22-2007, 08:13 PM
gerry hanley is on a distinguished road
can annyone help me setting up mach 3. off line . i made atuch probe and
want to test it. what i mean is can i solder the 2 wires to a rs323 d conector
and run mach ant se the dro worke i have not wired my routing cnc machine
yet . the tuch brope looks nice. and will ost photos when i am fimerlu with cnc zone and wood pe glad to help anny one thinking of build ing same
manny thanks gerry
Old 08-29-2007, 01:09 PM
Diatom is on a distinguished road
Thanks!
Our research group has a 7300 series machine from flashcut, with their tool changer and tool length sensor. The M06 macro does just what you are looking to do on our machine. You might see if flashcut has a standalone tool heigh switch for purchase.
4020 4th axis problems little bubba Fadal 3 06-13-2005 10:08 PM
Touch Probe Amplifier Modifications itsme General Electronics Discussion 8 06-07-2005 09:57 AM
Pop-up tool touch probe dmealer General Metal Working Machines 4 04-04-2005 07:47 AM
homemade 3D touch probe? cnczane DIY-CNC Router Table Machines 26 06-26-2004 08:17 AM
My Lathe project; might CNC it one day Stevie General Metal Working Machines 86 06-21-2004 09:27 PM
