Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > FlashCut CNC
FlashCut CNC Discuss FlashCut CNC software here!
Old 05-04-2004, 06:31 PM
Swede's Avatar
Swede is on a distinguished road
Servo position errors w/FC
I had the unhappy episode of ruining two pieces of work with the same G-code set. What was happening was a Z-axis position error... the motor simply stopped, while the other two axes kept right on moving! Both cases caused a 1/8" ball mill to plow deep into virgin metal with predictable results.
I can fix it by increasing (within DCN) the allowable position error, but what I'd rather have it do is slam the system to a halt. I thought this latter was the normal mode for FC + servo.
Any advice? I may as well increase the allowable error to very high levels, as at least then it will try to catch up and not simply kill just *one* axis of the 3.
Swede
Old 05-29-2004, 11:18 AM
Swede's Avatar
Well I found the problem with my system. I was using the stock limit switch harness, which is designed, I believe, for stepper systems. The three inputs which correspond to the servo axes were jumpered on the back of the 16-pin plug, creating a NC signal regardless of the state of the servo, which applies its signal through the DB25 cable.
After removing the jumpers, a servo fault now halts the system.
Moral: If you want your servo fault to be sensed by the software, be sure that the jumpers on the back of the input line harness are cut or removed. This was in the documentation, but buried pretty deep and not something that jumps out at you.
Old 05-29-2004, 06:17 PM
*Registered*
ESjaavik is on a distinguished road
Also check your control software to see if there is a max acceleration figure you can set so it doesn't try to ask the motors to ramp faster than they can, thus creating a too large following error.
What is a Servo ? ynneb FAQ of CNC Machine building 1 07-16-2005 02:29 AM
Servo Motor Running away. murphy625 CamSoft Products 38 02-27-2005 02:08 PM
Progress on my servo controller arvidb General Electronics Discussion 3 01-24-2005 10:14 AM
steppers or servo drives mmjpotter Gecko Drives 14 03-30-2004 03:56 PM
How does a servo hold its position? ynneb General Electronics Discussion 1 03-08-2004 10:10 AM
