Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > FlashCut CNC
FlashCut CNC Discuss FlashCut CNC software here!
Old 03-10-2004, 10:54 AM
ecope is on a distinguished road
Using BobCAD with Flashcut
Hello,
I am using BobCADCAM to generate G-code, now I need to get it into Flashcut.
What post or setup in BobCAD do I need to select or configure?
I will be using both the lathe and mill.
Thanks!
Eric
Old 03-12-2004, 01:19 AM
steveald is on a distinguished road
I don't use BobCAD, I use CASmate. The Precix servo driver works for me with CASmate and Flashcut, so if there is a Precix driver (post) in BobCAD I would try that, otherwise try a generic Fanuc post.
Steve
Old 03-12-2004, 10:18 AM
MikeA is on a distinguished road
Flashcut post available in v17. I or perhaps Bobcad tech support could e-mail you that.
We are open 24hrs. - just not in a row.
Old 03-27-2004, 03:08 PM
mc_n_g is on a distinguished road
All of the FlashCut posts are available from the BobCad support site. I run both 17 and 18 without any problems (mill only).
mc_n_g
Old 05-13-2009, 12:59 PM
klklein is on a distinguished road
When I want to make a quick simple part on my mill (I don’t know if it would work with a lathe) I draw it in BobCad then save it as a .DFX. then I import it into flashcut. You can also scan a drawing into a program like Coraldraw then save it as a .DFX. You may have to clean up the drawing before importing it to Flashcut.
Kerry
BOBCAD Model Airplane Wing Design Script cely BobCad-Cam 6 08-20-2009 11:11 PM
Importing polygon mesh (.dxf) into BobCad rherman BobCad-Cam 0 06-10-2005 03:08 PM
Bobcad Barracuda comments metlmunchr General Metal Working Machines 1 06-30-2004 02:36 AM
Flashcut Post Processor whiteriver OneCNC 3 12-15-2003 11:04 PM
