Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: Should I get Flashcut?
    Registered DonFrambach's Avatar
    Nov 2006
    I'm about to CNC a "CNC ready" bench mill. I'm seriously considering getting the Flashcut 3 axis Servo kit. I've come up with a list of pro's and cons and would greatly appreciate comments.
    Pros for the Flashcut CNC Servo
    1) USB interface rather than a parallel port. The USB interface may be much more reliable and available.
    2) Separate function generator so Windows multitasking may not be a problem.
    3) Servo motors that may have advantages over steppers.
    4) Complete kit available so there should be no compatability issues
    Cons
    1) Expensive (but not out of budget)
    2) Forced to use Flashcut software (this might not be a disadvantage if it is reliable and supported)
    Jul 2005
    I've been running FlashCut for 5+ years. I started with version 1.2 on Windows 98 running a ShopTask mill/lathe. I'm now running version 2.1.4 on XP. It controls a plasma table, ShopTask mill, and currently my Bridgeport Series 1 conversion. Solid as a rock. I only have experience with their steppers though.
    Their knee mill conversion uses Elrod Machine components. Which are supposed to be one of the best conversions.
    My two cents.
    Nicholas
    Nov 2006
    I ordered Flashcut!
    I ordered a Flashcut system yesterday.
    Jul 2005
    Did you order the USB or serial controller (Signal Generator)?
    Nov 2003
    Pennsylvania
    I have been running the FlashCut system for over 4 years without any problems. It is a stepper system with serial connection running a Sherline 5400 mill. Had no problems and is very staight forward.
    I dont understand your problem with running the Flashcut software. no matter what system you choose you are at the mercy of the software and how well it is interfaced with the system as a whole. It has weak editing tools but that is not what the main function of the program is for.
    mc_n_g
    Nov 2006
    I ordered the Flashcut sytem with the USB interface. I'm glad that the Flashcut software works so well for others and hope to have the same experience.
    Jul 2007
    If i bought a flashcut machine it wouldn't be for the tech support. Before you jump in deep and buy a new servo unit, do a search I have a flashcut servo system listed in the classifieds section that I am selling.
    jeff
    Registered Fleck's Avatar
    Dec 2007
    Alaska
    I have recently purchased the Flashcut 4400 lathe package. I have had very good luck with the customer support. They have always gotten back to me within a few hours after email, once on a sunday.
    Nov 2006
    Just wanted to report that I have had absolutely no problems with the Flashcut software. I upgraded to version 3 just to stay up to date. That required a firmware modification when tech support made quite easy. BTW Flashcut did not charge me for the software or firmware upgrade. I'm pleased!
    Nov 2003
    Pennsylvania
    Good for you. I hope it all continues to run well for you. I have had no problems with it at all. Still running 2.x due to older systems and chipsets.
    Nov 2008
    South Africa
    Hi there
    I was wondering how happy you are with your 4400 Lathe? What are the typical size components that you are able to machine? How is the accuracy?
    I am looking at purchasing this lathe, but being in South Africa, I need to be sure of its ability.
    Martin
    Dec 2007
    Alaska
    Hi Martin,
    I make musical instrument fittings, accuracy and repeatability are a must.
    I can keep my parts within .0015 plus or minus most of the time. That was after I bit the bullet and purchased the Sherline quick change tool, the less expensive other quick change tool I bought first would never re-seat with any accuracy. I am in a electrically noisy building with other motors on the same circuit, so a line conditioner was required.
    I am able to make 50 parts at a time and keep them within plus or minus .0015" most of the time.
    Ron and Nick at Flashcut are super helpful, they really went out of there way to help when I had questions or issues to work through. I always got an email back in 24hrs. I am a guitar builder and knew nothing about CNC before the purchase.
    Good Luck,
    Mike
  • Page 1 of 2 12 LastLast
    1. How do you like FlashCut?
      By CNCadmin in forum FlashCut CNC
      Last Post: 06-28-2011, 11:33 PM
    2. Will Flashcut work on the following?
      By Darc in forum FlashCut CNC
      Last Post: 09-17-2008, 04:16 PM
    3. Flashcut?
      By A&P Mech in forum General Metal Working Machines
      Last Post: 05-23-2006, 05:38 AM
    4. Flashcut 8300 Diy Possible?
      By WoodKahuna in forum DIY CNC Router Table Machines
      Last Post: 11-10-2005, 06:12 PM
