Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > FlashCut CNC
FlashCut CNC Discuss FlashCut CNC software here!
Old 12-26-2010, 09:02 PM
anoramose2007 is on a distinguished road
Flashcut for Cnc mill reto-fit
Looking at replacing my Bandit control on a SHIZUOKA CNC mill.This mill is used part time in my garage.Any one using Flashcut ?I'd like your opinion on software and support.I've talked to Flashcut saleperson a few times.They didn't have a any one to talk to in Twin cities(MN)area that has retrofitted with Flashcut Cnc .
Old 01-01-2011, 10:10 AM
RSid is on a distinguished road
MAXNC refit with Flashcut
After 4 years of using a MAXNC to make scrap out of perfectly good blanks, I switched to a Flashcut Compact USB controller as the brain for the MAXNC donor body. Rewired the steppers and I was up and running in under two weeks (I wanted to rewire but could have ordered plug and play steppers from Flashcut). Version 4 of Flashcut is current and its a good solid utilitarian CNC CAM program and it gets the job done.
Nice error checking and fairly standard control sets in Flashcut. No surprises or strange ways of processing signals. Will only import 2D DXF for Contour coutting. Once again, it just gets the job done. I like it and the support from Don is beyond excellent.
I use trueSpace CAD to design parts or LaserExpress to do just outlines for 2D DXF. I process the g-code for 3D DXF using DeskProto 5.0 (very nice program but loses a few points for requiring a USB dongle).
Hope this helps.
Cheers
Should I get Flashcut? DonFrambach FlashCut CNC 14 03-30-2010 07:34 AM
Flashcut 8000 Series Mill rynando Benchtop Machines 0 03-01-2009 05:32 PM
Need Help!- Flashcut/Sherline CNC Mill Capabilities asicman Benchtop Machines 0 01-18-2009 10:50 PM
Flashcut/Sherline CNC Mill Capabilities asicman General Metal Working Machines 0 01-18-2009 08:07 PM
FlashCut CNC Mill 2000 sniffles General Metal Working Machines 6 03-01-2006 06:27 PM
