Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > FlashCut CNC
FlashCut CNC Discuss FlashCut CNC software here!
Old 11-27-2010, 08:33 PM
mrehmus is on a distinguished road
FlashCut Compact Controller and V4 software
Just received these products and am attempting to revive Robert Washburn's old TAIG CNC mill.
2 axis work well. One axis does not. Might not start, may start if the knob is given a spin. May act as if there is no power after it stops jogging. That is, the knob can be spun as if it were powered down. Not so with the other axis.
Shinano Kenshi size 23 steppers of roughtly 200 Oz-In. torque.
I swapped X & Y steppers and their connection to the control box with the same results. The problem followed the stepper.
Cable looks to be intact but I'd like to take the rear cover off the stepper to check the cable all the way inside. Will I cause problems with this minimal opening of the stepper?
These steppers appear to like 1/2-stepping better than using 4 or more microsteps based only on the sounds I'm hearing. I haven't started using measuring equipment to really test what is going on.
Newbie- Flashcut (or other) kit with Mach software? GeeForce Mach Software (ArtSoft software) 0 05-26-2010 12:21 PM
Emco Compact 5, but now software... peter_m2 Benchtop Machines 3 10-01-2009 03:01 PM
NEW! 4D H2 Compact CNC Controller (with motor power supply)! icm Product Announcements & Manufacturer News 0 05-06-2009 09:56 AM
compact 5 software oblio1612 General CNC (Mill and Lathe) Control Software (NC) 0 09-24-2005 04:54 PM
We Need Flashcut Software!!! Mr. Roboto FlashCut CNC 3 01-15-2004 05:14 PM
