Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > FlashCut CNC
FlashCut CNC Discuss FlashCut CNC software here!
Old 08-16-2010, 10:46 AM
Carrie Anciaux is on a distinguished road
Unhappy FlashCut error message: lost connection with signal generator! HELP!!!
I use FlashCut CNC ver. 2.0.9 to cut sheet metal using a Hypotherm Plasma Cutter. I have started getting an error intermittently that states I have lost the connection with the signal generator, try turning off and on to reset/check connections etc. I have been unable to pinpoint where the problem is, but suspect it is in the Flashcut Signal Generator Box. I ordered a new 9 pin cable in the hope that the solution is that simple but have not received it yet. Has anyone else had this problem and can offer recommendations to fix?
Last edited by Carrie Anciaux; 08-17-2010 at 08:35 PM. Reason: Did not include title....
Old 08-22-2010, 11:23 PM
powerr is on a distinguished road
i had the same problem for awhile. i droped the communication baudrate down one level and it went away. still not for sure that was the problem. but it has not happened since.
Old 08-23-2010, 09:23 AM
Baudrate?
Thanks for the reply. What baudrate did you set it at? I looked at this as and was not sure if I should set it lower. I did get a new 9 pin cord and ran the power cord separately and that seemed to help. Thanks,
Carrie
Old 08-24-2010, 09:04 PM
i think before i had it at 115k baud and dropped it to 57.6k baud on version 2 i since have updated to version 3 software and a new chip for the 401 controller. it helped alot with the communication problem. but a good cable will help out as well.
Tags
error, flashcut, lost connection, signal generator
Iron Cad sanjiv General CAM Discussion 6 10-20-2008 08:51 PM
anyone know where to get a used iron worker? mik32176 Bending, Forging,Extrusion... 2 02-01-2007 04:45 PM
Yet another iron in the fire... BobWarfield Industrial Hobbies (Support forum) 18 07-02-2006 11:27 PM
RFQ For a Mountain Bike part Bender Employment Opportunity 17 08-18-2005 01:38 AM
