I poked around with the program and documented what I could. Does anyone know the hotkeys for Speeding up and Slowing down the RPM's for the Spindle ??
MAIN LEVEL CONTROLS
- SUB LEVEL CONTROLS
Gcode Panel = CTRL + G
- HOLD = (Any Key / Space Bar) When moving
- Jump to Line = J
- Cancel = L
- Go = G
- Faster Feed = CTRL + Up Arrow
- Slower Feed = CTRL + Down Arrow
- Restart = R
- Start = C
- Step = S
- Continuous = C
Jog Panel CTRL + J
- X AXIS + = CTRL + Right Arrow
- X AXIS - = CTRL + Left Arrow
- Y AXIS + = CTRL + Up Arrow
- Y AXIS - = CTRL + Down Arrow
- Z AXIS + = CTRL + Page Up
- Z AXIS - = CTRL + Page Down
- A AXIS + = CTRL + Plus (+) Key
- A AXIS - = CTRL + Minus (-) Key
- Fast Jog Speed = T
- Medium Jog Speed = D
- Slow Jog Speed = W
- Contunous = O
- 0.1 = O ~ Down Arrow
- 0.01 = O ~ Down Arrow ~ Down Arrow
- 0.001 = O ~ Down Arrow ~ Down Arrow ~ Down Arrow
- Step = E
- Hold = (Any Key / Space Bar) When moving
Point Panel = CTRL + P
- Any Point = SHIFT + 1
- Program Zero = SHIFT + 2
- Machine Zero = SHIFT + 3
- Relative Zero = SHIFT + 4
- Tool Change Position = SHIFT + 5
- Program Start Point = SHIFT + 6
- Current Line Start Point = SHIFT + 7
- Last Feed Hold Point = SHIFT + 8
Home Panel = CTRL + H
- Seek Home = K
- Fast Home = A
- Feed Hold = (Any Key / Space Bar) When moving
Aux Panel = CTRL + A
- Spindle (ON / OFF) = CTRL + 1
- Tool Change (ON / OFF) = CTRL + 2
- Flood Coolant (ON / OFF) = CTRL + 3
MDI Panel = CTRL + M
Probe Panel = CTRL + B
Faster Spindel RPM = ?UNKNOWN?
Slower Spindle RPM = ?UNKNOWN?
Edit Loaded GCODE = CTRL + E
New GCODE File = CTRL + N
Open GCODE File = CTRL + O
i cant find that either. you may have to give them a call. it can be done through their pendant so i would think there would be a key board short cut for it.
