New Machine Build what have you put flashcut cnc onto ?
Results 1 to 4 of 4
Thread: what have you put flashcut cnc onto ?
    Registered gfmer18's Avatar
    Mar 2017
    Default what have you put flashcut cnc onto ?
    I have put Flashcut Cnc onto these machines....machining center and a turning center
    Attached Thumbnails Attached Thumbnails what have you put flashcut cnc onto ?-mill-n-lathe-jpg
    Mar 2004
    Wisconsin
    Default Re: what have you put flashcut cnc onto ?
    What a fun topic !
    1. A Western Engravers 2448 Router
    Had OEM, then Ah-Ha!, Finally Flashcut
    2. Digital Tool CNC Router (2 of them)
    1 Had OEM, then Ability Systems Indexer LPT, Finally Flashcut
    Other had OEM, then Flashcut
    3. A Data-Cut CNC Router
    Had IndexerLPT, toyed with Mach, then finally real with Flashcut
    4. A New Hermes 7200 Engraver
    Had OEM, then Flashcut
    5. A Western Engravers 1624 Engraver
    Had OEM, Tested and toyed with Mach3 and LinuxCNC, but finally Flashcut
    6. A Novakon NM200
    Had Mach3, but very quickly retro'd to Flashcut
    7. A Grizzly G0704 Conversion
    Flashcut all the way......
    8. A Denford Orac CNC Lathe
    9. Two Different Home built engraving machines
    Only Flashcut
    10. Two Different Home built CNC plasma machines
    Only Flashcut
    11. A close friends home built CNC Router
    Had DeskNC, but first productive with Flashcut
    12. Have my eye on a dead Multi-Cam currently.
    Care to guess what It will run ? Lol.....
    Hope I did not forget any. Some I own, some I sold, some I retrofitted for others. My little black S/G boxes get a lot of miles on them as I simply could not afford to have a dedicated control on all of them. What an excellent program though... I've been impressed since late 1996 or early 1997 and have not regretted a thing.
    If I ever get my life back, I intend to build some more machines !
    - - - Updated - - -
    What are your machines by the way ? Very nice if home built !
    Jul 2011
    2x2 torchmate growth series - I put flashcut controls on
    MaxNc 15 CNC mill - flashcut controls
    MaxNC15 - currently under construction
    Torchmate 2x2 with Flashcut CNC Controls
    Nov 2012
    Acra knee mill....never lets me down!
