- Need Help!- **NEWBIE**Need suggestions for Cad CAM to run older software.
I recently purchased a CNC Plasma table running Flashcut version 2.0.9. I need to purchase CAD CAM software to draw and design with. Im having trouble finding which Cad Cam programs to use. I called Flashcut's tech support line and they tell me I have to update to their USB software. The version I have should work as I watched it run before purchase. There is no doubt about it that I am a newbie to cnc but have to start somewhere. I will be running a Windows XP Desktop. Thanks for any and all help!
Re: **NEWBIE**Need suggestions for Cad CAM to run older software.
I run XP with older 32bit CAD CAM
PM me for more info.
What is your experience with this type software, this means a lot as to what you need.
I run XP with older 32bit CAD CAM year 200
What is your experience with this type software, ?
What machine?
Old software is fine, We made space shuttles with punched cards and mainframes on fortran.
You can draw and design with other software and just import the dxf to flashcut. I did that before i bought the full software.
Adobe illustrator can export to a dxf. Corel draw.
Draft sight and inkscape are free and can export to a dxf.
Which table did you buy? I am on version 6.0.6.104 I think for the software
- You may not post replies
- You may not edit your posts
Forum Rules
