Setting machine 0 with code
Results 1 to 3 of 3
Thread: Setting machine 0 with code
    Registered tony978's Avatar
    Jun 2009
    Default Setting machine 0 with code
    Does anyone know if you can set your machine zero with code . I want to prove the a lol on the table to set it not use switches
    Thank you
    Tony
    Mar 2004
    Wisconsin
    Default Re: Setting machine 0 with code
    Quote Originally Posted by tony978 View Post
    Thank you
    Tony
    Not sure what "prove the a lol on the table" is, but if your trying to set zero from a current position, see G92 commands. If you want to set zero based on seeking a switch, look at G31 commands.
    You can create a macro to put the two functions together if necessary.
    Chris L
    Jun 2009
    I did see that but I was trying not to have to mod my post again .
    Tony
