I think that most people on cnczone are hobbyists and flashcut is to
costly for that purpose.
Nobody actually uses Flashcut...
I use Flashcut, and it never has issues, so no posts...
I use Flashcut, but I am so busy trying to get it to work I don't post...
Other (Please clarify in post)...
So, why is the traffic so low?
- Looking For A Job- general discussion
- surprised by accuracy
- Newbie- Pleasantly surprised by Chinese laser machine
- New Machine Build- I want to make surprised
CAD, CAM, Scanning, Modelling, Machining...
If you don't mind me asking what is Flashcut..? And for what CNC application would you use it for, i.e. plasma, Mill, Lathe, router etc… and then I will be able to participate in your poll...
Eoin
It is a controller alternative to MACH3 and EMC2 that are pretty popular. It is more expensive and is integrated with more specific hardware than MACH and EMC. However, it also seems to offer much more robust operation and compatibility with servos, etc. Unfortunately, counting on support from this board, given the responses to this post, seems very unlikely... The MACH and EMC boards would have hundreds of posts on a thread like this, where this post has only 117 views and 2 responses so far...
CNC Controller Software and Signal Generator
Got a quote. The hardware and software for 5 axis step and direction control is $1295. A controller for the spindle is $495. They also sell cards to do servo control and stepper drivers. It can all be spec'd for OEM purposes. The reason I was looking at it at all is from this YouTube clip:
http://www.youtube.com/watch?v=b-y03hhCCME]UMC 10: Scratch Built CNC with Automatic Tool Changer - YouTube
This thing puts my Mikini to SHAME, and won't cost much more (and will be ALL closed loop servo axes, toolchanger included, etc.). I was interested in finding out what FlashCut was as well, which is the reason for the pole...
He shows it running on Win7, it is only USB connected to the computer, and the signal generation is done purely by the box. That means your computer/running programs will have NO effect on the CNC operations. VERY nice benefits over MACH, and it keeps a Windows interface for those that don't want to mess with EMC...
No, that is "just" the step and direction signals for up to 5 axes of simultaneous motion. Yes, it is "much more" than MACH3 at $150 (as I recall) and EMC (free), and the installed base is MUCH less than those two. However, I also see it as much more of a "real" VMC-like system control. It is able to do closed-loop control "out of the box" as well.
BTW, I have nothing to do with the company, and have ZERO experience with it. Other than the price, though, it sounds almost "too good to be true", which is why I am trying to get some input from users here. As you can see, of course, that's not going too well...
Maybe it really is "too good to be true"?
Interesting video and as I'm new to CNC I haven't used EMC so I won't compare it but using Mach3 for the past 6mths and only finished my BF20L Mill conversion to CNC, I must be missing a point in this thread as I'm not sure where the advantage of using Flash Cut over Mach would come in....... in my electronics setup I am using the Smooth Stepper from Warp9 Warp9 Tech. Design - Home of the SmoothStepper - Home and this takes nearly all the processing work from the host PC and is connected via USB also (so no PC Parallel ports needed) and I'm using the C32 bob from CNC4PC CNC4PC.
Apart from my learning curve I can only say that as a 6 axis controller for $175 with continous acuracy, I don't see the advantage of Flash Cut for the price....
Eoin
I think for 90%+ users, your statements are spot on, maybe... That said, if you run MACH, you should NOT run anything else. I think with Flashcut, you could also run your network, stream Pandora, watch a movie, and do some CAD and CAM work all at the SAME time as using the CNC (while it is cutting), and you would see zero impact on the part being cut. In addition, you could run CURRENT hardware and Windows7, and take advantage off 64-bit software as well. Again, you may not care about any of that, and that is fine. I think there ARE people who would find that interesting, though.
In addition, I think alot of the solutions available on MACH are open source. On the one hand, this is great. It makes tons of options available. On the other hand, if it breaks, you are dependant on a forum to help you. FlashCut is closed source, and if you need help, they have a phone number for support and claim it is fully staffed.
Finally, I have heard that their customer service is great. If you need help setting up closed loop controls etc, they are there to assist.
Again, this is all what I understand to be the situation, but complete silence from actual users on this board is at a minimum disappointing... That said, maybe they are all so busy running their machines while they stream Pandora, watch a movie, and do some CAD and CAM work on the same PC... :rainfro:
First off, I TOTALLY agree they MUST put something regarding price on their site! I told them the same when I contacted to get a price. I was afraid the answer was going to be $10k or something, but instead it makes it worth looking in to further given the price they did quote...
Here is what I understand. You use their proprietary PC software on your computer. The PC software connects to their (up to) 5-axis control box via a USB connection. Communications occur between the PC and the control box, but it is "high level" and has zero time dependence. The control box takes the "high level" communication and creates the bit-for-bit control datastream that is sent out.
I do not know if the control box contains drivers or not. I seem to doubt it. I believe it is just the control signals - it is up to the user to then pick a stepper or servo controller to pair with the control box. This is an assumption as yet, though, I need to look in to it further.
Since the PC and the control box are connected via USB, and are in no way timing dependant, the PC can be doing whatever it wants at the same time (unlike MACH3). In addtion, the PC can run Windows7 (unlike EMC). While Flashcut is running, I believe the user would be free to do whatever else they want - stream Pandora, watch a movie, watch YouTube!, run a CAM program, design in CAD, or all of the above. All while your machine is cutting away under control from Flashcut in the background.
OK, so some of my statements appear to be wrong, anyway.
There are two discrete systems. One for steppers, which includes stepper drivers in the box, and one for encoder-feedback servos, which includes servo drivers in the box. There are different power levels and features available for both boxes. They also sell motors that work with the system, but state that openly available motors (stepper and servo) can be driven by their drivers...
I am still intrigued, and I asked the person that responded to my info request to post in this thread. We'll see what happens, I guess!
Here's a link to the servo options:
Servo Control Systems Specs
My guess now is that my quote was for a 5-axis stepper oriented system with the lowest cost drivers included, but to be honest I don't now (was not provided a part number or technical reference for what was specifically included). I just wanted to know a ballpark number in order to determine if it is worth proceeding to get other info or not...
I can see similarities with Flash Cut and my DIY electronics setup using the Smooth Stepper from Warp9 but for a tenth of the price however the fact that a PC running Flash Cut has the ability to run separate windows based software is a definite plus against my Mach3 setup.
However, then again obtaining a separate (second) PC on Ebay for cents and using the Smooth Stepper would solve that problem. I have no commercial ties with Warp9 either…
Here is a brief explanation of the Smooth Stepper and this quote is extracted from Smooth Stepper Manual http://warp9td.com/documentation/Smo...ManualV1.0.pdf The Smooth Stepper receives movement instructions from the motion planner in Mach3 and produces step and direction pulses for motor controllers that accept that form of control, either servo or stepper. In addition, the Smooth Stepper provides spindle control and can handle all the other Input/Output (I/O) functions that are normally handled by the two printer ports under Mach3. By taking over the task of producing step and direction signals, the Smooth Stepper relieves the host computer of most of the CPU load normally involved in running Mach3. The dedicated hardware in the Smooth Stepper produces pulse streams up to 80 times faster, and with more precise timing than Mach3 using the printer port.and the operating sequence as follows:
Mach3 ↔ Smooth Stepper Plug In ↔ Smooth Stepper USB driver ↔ Smooth Stepper device ↔ Breakout Board ↔ Motor Drivers ↔ Motors……”
I suppose from a commercial viewpoint Flash Cut may have advantages and I must admit too that Flash Cut does seem like an interesting option but maybe not for those of us using CNC for hobby purposes. But this thread was started as a poll rather than a FlashCut comparrison platform.
Last edited by Mad Welder; 11-16-2011 at 11:30 AM. Reason: missing link for Warp9 Manual
Eoin
When I retrofitted my machine, I looked at the flashcut site for information. It seemed like what I was looking for.
Like everyone else has said, there was no pricing structure or any price info whatsoever!
I figured, if they can't say the price, it's probably too high anyway. If the prices are what was posted here, and I had known that, I probably would have gone with Flashcut.
I use Mach3 now, but would rather have a 100% reliable machine than one I could experiment on with different software tweaks.
Maybe next time.
mcphill,
I use FlashCut on my MiniTech 3 mill running closed loop servos and it has been working perfect for me. I bought my mill on ebay and FlashCut helped me upgrade to a 4th axis/rotary. Last year I upgraded to the USB Signal Generator. The only problem I'v had is one motor driver went out and tech/support helped me trouble shoot and got me going fast. I use my mill every day cutting was for jewelry casting.
Mike
Thanks for the feedback. I had a very long conversation with them on Wednesday and I think I am sold for my next build. I will be going to servo's, and I think the system being an "all in one" package has a TON of user benefits. Given I have never heard a negative comment from any users, I hear great comments about their customer support, and the pricing I find surprisingly low for what you get, it seems like a no brainer!
It's definitely as you say a no brainer and I like the fact of a genuine human on the other end of the phone support team.
And then again I'm not in any way blemishing or knocking the Mach support forum as I myself am a happy Mach3 licensed user without any complaints and in my humble opinion the Mach forum really is fantastic.
However the fact that Flashcut doesn’t “take over” the host PC like Mach really is a huge plus AND being able to run your CAD from the host PC while a part is being machined……and also run 64bit Windows7……WOW.... now there’s your no brainer answer in full…..
Eoin
LOL ! That's some comedian who voted for "nobody uses Flashcut" ! Har !
Seriously, it's probably the best kept secret out there. It just plain works. They do not release software thats still "developing", which is a major plus for guys who do not have time to be a beta tester. It's an organized control, serving all the features 98% of machine users could want, all wrapped up in one of the easiest to use, easiest to understand controllers ever.
Between home and work, I've got a 6' x 10' router, a 30" x 48" router, an NM 200 Novakon mill, a 12" x 15" engraver, a 4' x 4' Plasma cutter and another plasma cutter on the way, ALL controlled with FC. They use a variety of different drivers.....
I've played with mach... heck, the Novakon came with Mach, but I just couldn't wrestle with quirks any longer. For some reason, controlling the spindle RPM was a constant aggravation, and for whatever other reason(s), it kept forgetting its settings. The conversion to FC was as easy as a new crossover cable. Now its been rock steady for almost a year.
I don't believe that they officially recommend that you check your email or draw while the machine is running though. As some already know, it might not be the best idea when a second networked PC is affordable these days. However, I will admit, I've often popped open the file manager and looked for the next job, switched over to media player to change songs (ya,,, an operating cnc control, cutting AND playing my mp3's - does Haas do that yet ??), and even have opened a browser to see what Matt Drudge may have been reporting on a busy news day.
Lastly, that UMC-10 video posted earlier sure looks great. I found it incredibly interesting that a fellow with a VMC, who worked selling a brand name VMC, built his own VMC and then chose Flashcut to run it. Now there's things that make you go H'mmmmm...
Chris L
Flashcut is a nice piece of work. If you want a turnkey system, seems like a good choice. I wish they would publish their prices, rather than require quotes. It always seems like some sales guy wants to negotiate when companies do that, big turn off.
With that said, not clear Mach3 or EMC really is 1/10 the price. You have to remember, Flashcut offers a complete system. So, you have to price in all the break out boards, servo or stepper drivers, power supply, spindle control, and so on.
Assume Mach3 at $175, a power suppy for maybe $169 (Kelling), 3 stepper drives from Gecko @ $121 apiece, some kind of BOB for another $100 or so, a case, miscellaneous other components, your time, etc. etc.
Folks, you just spent the best part of $1000 and you don't necessarily have it working yet, LOL. For those that want to get on with making parts, or who are strong on mechanical but feel challenged on the electrical/software side, Flashcut might be just the ticket.
One of the most important parts I haven't even mentioned, and that's having some kind of hardware pulse train generation, which Flashcut offers. That'll add $165 for a Smoothstepper or other to the Mach3 side bringing prices still closer.
I've written a couple of articles over on CNCCookbook about the importance of these boards:
Motion Control Boards Take Mach3 From Hobby Class to Industrial Grade, Part 1 « CNCCookbook
I think they really matter to taking performance from hobby class to industrial grade. Not to mention they let you surf the Internet and play your MP3's with Mach3 running a job, LOL.
Best,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Thanks for your comments, Bob. I bought a SmoothStepper with my Mikini but never bothered to hook it up. I didn't realize I was leaving performance improvements on the table by making that decision! I will get that puppy installed ASAP now!
McPhil, to be clear, the jury is out on whether simply adding a Smoothstepper with no other changes will make a big difference on the Mikini. It depends on how stable the interrupts are on your PC (you can test that with DRIVERTEST.EXE) for one thing. It also depends on whether returning things around smoothstepper can be done.
Also, keep in mind that while Smoothstepper recently got backlash comp, it still has problems if you make moves less than the amount of backlash you have. So, if a lot of comp is dialed in on the Mikini, that won't be happy.
At the very least, I would think the system gets more reliable and you can reliably do things like access the Internet while running a job though. I also can't see how it hurts, other than the backlash issue and the additional cost and complexity. It just may take some overall tuning and fiddling to extract maximum benefits.
Best,
BW
