When I load it into Mach3, I get a zero length arc error on that line. I get the error as soon as I load it, so I don't know why you are able to run it.
Trying to run a tiled file from Aspire 9 on a Saturn 2, CRP NEMA 34 Plug and Play. First tile ran fine, the second tile has 3 toolpaths - counterbore, holes and cutout. The counterbore ran fine, but when I get to the cutout (same tool) it starts the cut, gets to the first radius and stops the feed. Spindle still turns, but no feed.
It's at line 23 of this code:
( T2_Front edge cut )
( File created: Thursday January 18 2018 - 07:12 PM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 60.000, Y= 60.000, Z= 1.000)
(Toolpaths used in this file
(Front edge cut)
(Tools used in this file: )
(1 = End Mill {0.375 inches})
N100G00G20G17G90G40G49G80
N110G70G91.1
N120T1M06
N130 (End Mill {0.375 inches})
N140G00G43Z0.8000H1
N150S18000M03
N160(Toolpath:- Front edge cut)
N170()
N180G94
N190X0.0000Y0.0000F225.0
N200G00X16.2420Y-0.0010Z0.2000
N210G1X16.2420Y-0.0010Z-0.3775F75.0
N220G1X16.2420Y5.6250Z-0.3775F225.0
N230G3X15.6875Y6.1795I-0.5545J0.5545
N240G1X14.8125Y6.1795Z-0.3775
N250G2X14.6170Y6.3750I0.0000J0.1955
N260G1X14.6170Y17.6250Z-0.3775
N270G2X14.8125Y17.8205I0.1955J0.0000
N280G1X15.6875Y17.8205Z-0.3775
N290G3X16.2420Y18.3750I0.0000J0.5545
N300G1X16.2420Y30.0000Z-0.3775
N310G00X16.2420Y30.0000Z0.2000
N320G00X16.2420Y-0.0010Z0.2000
N330G1X16.2420Y-0.0010Z-0.7550F75.0
N340G1X16.2420Y5.6250Z-0.7550F225.0
N350G3X15.6875Y6.1795I-0.5545J0.0000
N360G1X14.8125Y6.1795Z-0.7550
N370G2X14.6170Y6.3750I0.0000J0.1955
N380G1X14.6170Y17.6250Z-0.7550
N390G2X14.8125Y17.8205I0.1955J0.0000
N400G1X15.6875Y17.8205Z-0.7550
N410G3X16.2420Y18.3750I0.0000J0.5545
N420G1X16.2420Y30.0000Z-0.7550
N430G00X16.2420Y30.0000Z0.2000
N440G00Z0.8000
N450G00X0.0000Y0.0000
N460M09
N470M30
Any thoughts? I've regenerated all the toolpaths, re-saved to g-code, etc. Same issue.
Thanks in advance!
Mick
UCCNC 2017 Screenset
The J should be 0 in that line.
N230G3X15.6875Y6.1795I-0.5545J0.0
Thanks Gerry. That was the problem. Now to figure out why 3 different posts are outputting it the same way.
What post processor are you using?
I'm not at the controller right now, but from memory we've tried Mach2/3 Arcs (inch) (*txt), G Code Arcs (inch) (*tap) and G Code (inch) (*.tap).
I've never heard of any Vectric software outputting incorrect code. I'd send the files to Vectric and ask them about it.
Mick,
I agree with Ger21. Our standard support process is for you to submit a ticket to Vectric support. Contact Us
Fine Line Automation
www.finelineautomation.com
Thanks guys. I'll do it and let you know what they say. Appreciate the help!
Saturn 2 4848
CRP Plug & Play NEMA 34, 2.2kw Spindle, Mach3
Mick,
Did you get this solved?
Thanks for checking back, Nate.
I haven't contacted Vectric yet. Did a workaround for that file in EnRoute and I had a good bit of prep work for class yesterday. I'll forward the g-code to them tomorrow.
Saturn 2 4848
